Old 01-27-2024, 06:39 AM   #1
flathead48
Default Rear panhard bar stud
Has anyone replaced the rear stud for the panhard bar ? If so , the best way to do it .
Thanks, Rick
flathead48 is offline   Reply With Quote
Old 01-27-2024, 12:56 PM   #2
blucar
blucar's Avatar
Default Re: Rear panhard bar stud
Thanks, Rick
I would assume you are referring to a '46-48 rear end because vehicles earlier than 46 did not have panhard bars.
Bill.... 36 5 win cpe
Old 01-27-2024, 01:46 PM   #3
flathead48
Yes, thank you
Old 01-27-2024, 02:20 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
Doesn’t it have a pin through it to secure it in the housing?
Ken/Alabama is offline   Reply With Quote
Old 01-27-2024, 03:20 PM   #5
Angledrive
Angledrive's Avatar
Remove pin, heat perch with fire wrench, beat the piss out of the stud.
Angledrive is offline   Reply With Quote
Old 01-27-2024, 05:00 PM   #6
flathead48
Thanks guys, don’t see a pin but will look harder.
Rick
Old 01-27-2024, 07:22 PM   #7
Ken/Alabama
Rick
The two I have has pins.
Old 01-27-2024, 09:36 PM   #8
petehoovie
petehoovie's Avatar
Old 01-28-2024, 06:47 AM   #9
flathead48
Probably too much paint on mine, thanks , I will find the pin.
Rick
Old 01-28-2024, 01:36 PM   #10
blucar
blucar's Avatar
The pix that Ken/Alabama posted in his reply to this thread clearly shows the shock mount on the diff housing. If the pin and/or mount are not clearly visible on the rear end, you possibly have two problems.. One: you don't have a '46-48 rear end or someone cut the mount off.
The oval headed pin that is shown in the pix is actually a large rivet that will require cutting the riveted head off of in order to drive the large rivet pin out and remove the shock stud.
Old 01-29-2024, 09:40 AM   #11
flathead48
Found the pin, thanks guys
Rick
