Old 10-05-2023, 02:14 PM   #1
[email protected]
joe.manfre@me.com's Avatar
Default Door lock cylinder removal
1930 door lock cylinder located in the door panel, not in the handle.
How do I remove it?
I do not have a key and want to bring it to the locksmith to get a key made.
joe.manfre@me.com is offline   Reply With Quote
Old 10-05-2023, 04:26 PM   #2
ModelA29
ModelA29's Avatar
Default Re: Door lock cylinder removal
delete - wrong info
ModelA29 is offline   Reply With Quote
Old 10-05-2023, 06:35 PM   #3
figment
Look in the door jamb for a small set screw . You will have to remove it then you can pull the lock straight out .
figment is offline   Reply With Quote
Old 10-05-2023, 07:21 PM   #4
JayJay
If it’s a four door, the set screw is actually quite large. I don’t have mine here but it’s like 5/16” or 3/8”. It’s on the door just below the catch.
Once you get it out, look for a key code stamped on the shaft. Your locksmith may be able to translate that to a pin pattern.
If you have an original and can get a key made, go for that. The replacements from the vendors (or at least the one I got) are POS.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 10-06-2023, 06:51 AM   #5
[email protected]
Thank you
