Old 10-02-2023, 09:48 AM   #1
Seth Swoboda
Seth Swoboda's Avatar
Default 1937 Temp sender & service replacement head
I just installed a fresh engine in my 1937 Ford. This is a daily driver car. The issue that came up is the engine has service replacement heads. The head does not allow the temp sender bulb to bottom out. It will pass straight through the head. I just caught this. Is there anything I can do, other than pull the head off and put on a Ford script head? I'm trying to save $90.00 on head gaskets.
Seth Swoboda is offline   Reply With Quote
Old 10-02-2023, 10:30 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1937 Temp sender & service replacement head
Seth,You need the adapter that has pipe thread for the head and a seat for the bulb. John Wolf in OH has those.
Here is a pic of it.
deuce lover is offline   Reply With Quote
Old 10-02-2023, 10:32 AM   #3
Seth Swoboda
If I use the adapter, will my sender unit sill thread into the adapter? Can you PM me the contact for John Wolf?
Old 10-02-2023, 10:36 AM   #4
deuce lover
Yes the threads are correct for the nut on the gauge.Here is John's info:
https://www.google.com/url?sa=t&rct=...c&opi=89978449
Williamson's and even Third Gen and Fred at Southside Obsolete might have it also.
Old 10-02-2023, 10:43 AM   #5
Seth Swoboda
Got it. Thank you!
This is my first experience with service replacement heads.
Old 10-02-2023, 10:53 AM   #6
deuce lover
You're welcome ! PS ,Even OEM heads from '37-'48 have the port with pipe threads.
Old 10-02-2023, 11:02 AM   #7
19Fordy
19Fordy's Avatar
You can also drill out a Weatherhead fitting available from NAPA.
Old 10-02-2023, 12:45 PM   #8
Zeke3
Zeke3's Avatar
Or you can e-mail Fred at Southside Obsolete to see if he has one of those adapters. Deuce-lover’s picture above shows the part number.
Zeke3 is offline   Reply With Quote
