#1 |
I'm rebuilding my '39 transmission. Van Pelt book says nothing about packing the 7025 and 7065 roller bearings with grease, nor does Wired Custom's video. Should they be packed? If not why?
Thanks for your help |
#2 |
Just done one of these ,transmissions don't use grease , a little oil on the needle rollers on assemble, before you put the lid on pour the oil over all the gears .Dont use sealed bearings on the rear ,
#3 |
Just use some of the gear oil you are going to put in the finished product.
As long as not dry, it will be fine.. |
#4 |
Thank you!
#5 |
I have a clear ketchup bottle I bought at the Dollar Store full of 600W oil. I use it on all the bearings and thrust washers. Same with rear end bearings
#6 |
#7 |
I do the same, I found the oil will mostly run to the bottom of the transmission if it sits awhile, I like all parts well coated before startup.
#8 |
I use "transmission assembly goo", yes thats the product name. Good for sticking the thrust washers on , and sticking on the roller bearings. especially on the later needle type bearings
#9 |
That is a good point - if you happen to have a transmission with individual cluster needle bearings, you need something to hold them onto the cluster wall when you insert the main cluster shaft. I usually just use grease . . .
