Old 03-31-2011, 01:42 PM   #1
oldford
Default Exhaust gaskets that do not stick
I'm installing new exhaust gaskets on my 36 engine manifolds and would like to know if there is some type of release agent that i can put on the gaskets to keep them from sticking on the block when I remove the manifolds later. I remove the manifold every winter to install a hot air manifold and it's difficult to scrape all the gasket material that is stuck to the block.
oldford is offline   Reply With Quote
Old 03-31-2011, 01:43 PM   #2
DICK SPADARO
Default Re: Exhaust gaskets that do not stick
Never seize works really well, coat both sides and they are usually reusable
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 03-31-2011, 07:02 PM   #3
Kahuna
Kahuna's Avatar
Mac's sells some very nice copper exhaust manifold gaskets that can be reused many times
Kahuna is offline   Reply With Quote
Old 03-31-2011, 07:33 PM   #4
Jack E/NJ
Jack E/NJ's Avatar
Dick Spadaro wrote>>>Never seize works really well>>>
Ditto. A little never-seez goes a long long way.
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 03-31-2011, 07:54 PM   #5
ken ct
Where did you see these in Mac's catalog,i cant find them?? ken ct.
ken ct is offline   Reply With Quote
Old 03-31-2011, 08:12 PM   #6
oldford
I can not find anybody that has them. Wish I could. Sounds like a good solution.
Old 03-31-2011, 08:39 PM   #7
jdl
jdl's Avatar
Send a message via ICQ to jdl
I found these, looks like they might be a good idea!
http://www.thehotrodcompany.com/shop...ct_id=91013599
jdl is offline   Reply With Quote
Old 04-01-2011, 10:15 AM   #8
Coupe35
Did ford even use exhaust gaskets?
Coupe35 is offline   Reply With Quote
Old 04-01-2011, 10:17 AM   #9
Henry/Kokomo
Henry/Kokomo's Avatar
I agree with Dick Spadaro and Jack E/NJ. A good, inexpensive and easy answer.
Henry/Kokomo is offline   Reply With Quote
Old 04-02-2011, 05:01 AM   #10
coupe5w36
coupe5w36's Avatar
I've often fitted both cast iron manifolds and headers using good old black automotive silicone in place of a gasket. Never had a problem with removal, & simply scrape the surfaces clean with a razor blade.
coupe5w36 is offline   Reply With Quote
