Old 07-15-2023, 01:51 PM   #1
Duke
Default Torque tube bearing Race
Hi,
I cleaned up the NOS torque tube race I purchased and it has lots of pitting. My original has wear groves where the bearing cage rides. Which on is better to use or should I find a better one?
This is a late 32 tube with no center bearing.
Duke is offline   Reply With Quote
Old 07-15-2023, 01:58 PM   #2
jimvette59
jimvette59's Avatar
Default Re: Torque tube bearing Race
NOS or not throw it out and buy a new one. JMO.
jimvette59 is offline   Reply With Quote
Old 07-15-2023, 02:09 PM   #3
19Fordy
19Fordy's Avatar
Don't gamble using a bad race even if it's supposedly NOS. Buy a new race and a new FORD made bearing with grease seal.
https://www.fordbarn.com/forum/showthread.php?t=83166
Be sure and read this thread:
https://www.fordbarn.com/forum/showt...e+bearing+seal
Old 07-15-2023, 02:16 PM   #4
Flathead Fever
Flathead Fever's Avatar
It doesn't take much of pit to make noise. It's amazing how loud little pits can be. It's too much work not to do it right the first time.
Flathead Fever is offline   Reply With Quote
Old 07-15-2023, 02:24 PM   #5
Duke
I need to find a new race, thank you.
Old 07-15-2023, 03:47 PM   #6
19Fordy
19Fordy's Avatar
Duke: Contact Mr. VanPelt.
http://www.vanpeltsales.com/FH_web/r...prices-pg2.htm
Old 07-15-2023, 04:33 PM   #7
Duke
Are the model A ones the same as V8?
Old 07-15-2023, 05:25 PM   #8
Lawrie
Lawrie's Avatar
Yes
Lawrie is offline   Reply With Quote
Old 07-15-2023, 06:05 PM   #9
oldbugger
oldbugger's Avatar
My experience with non oem ones is not good. JMHO
oldbugger is offline   Reply With Quote
Old 07-15-2023, 06:19 PM   #10
Duke
I have the same concern, I am looking it my parts stash to see if any torque tubes have a good oem unit
Old 07-15-2023, 06:39 PM   #11
Duke
Just pulled this out of another tube, no groves, not sure if the difference in color is wear?
Old 07-16-2023, 10:58 AM   #12
19Fordy
19Fordy's Avatar
If possible, install each bearing you have in the tube and measure the ID of each.
Post #13 in thread below shows how to make a sleeve remover out of PVC pipe.
Old 07-16-2023, 02:31 PM   #13
petehoovie
petehoovie's Avatar
