Old 06-03-2023, 08:50 AM   #1
Martinbuilt
Default Rivet source
Hi.
I'm trying to repair my cowl ('29) with parts from another.
Is it possible to get rivets to re-attach the subrail extensions, and connect the sides to the firewall?
I have catalogs for snyders and mikes, and only frame rivets are listed. What about these smaller sizes?
Martinbuilt is offline   Reply With Quote
Old 06-03-2023, 08:56 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Rivet source
JayCee Rivets. But you so have to buy a box…usually 100.
Have to know your sizes and type head.
Oldbluoval is offline   Reply With Quote
Old 06-03-2023, 09:00 AM   #3
rotorwrench
rotorwrench's Avatar
Those are likely 3/16" brazier head types. Most of the subframe parts were joined with those on the steel framed car bodies. 3/16" round heads are also available from model A sources. Ford used steel rivets for body and frame. I usually buy the longest size and then cut them down for shorter applications
Old 06-03-2023, 09:23 AM   #4
Martinbuilt
Thanks
Old 06-03-2023, 09:40 AM   #5
oldspert
oldspert's Avatar
Try McMaster-Carr. They are a great source for hardware of all types and sizes.
oldspert is offline   Reply With Quote
Old 06-03-2023, 11:32 AM   #6
Stew Masche
Stew Masche's Avatar
I have bought rivets from the outfit listed below.
They have a large assortment of rivets, tools, and supplies. A good company to work with.
I think they sell by the pound.
Hanson Rivet & Supply Co.
13241 Weidner Street
Pacoima, CA. 91331
800-777-4838
www.hansonrivet.com
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 06-03-2023, 04:09 PM   #7
rotorwrench
Big Flats Rivet used to be the go to source for antique Ford rivet types but they closed shop last January and retired.
Hanson is a larger scale outfit so a person has to know what they are looking for with them. The brazier head rivets can also be referred to as oval head or truss head types so be aware. Most of the early Ford parts sources stock rivets for model As. They also have some tooling. ATS is an aircraft tool source but a lot of what they have is geared toward aircraft work and can get expensive. I bought that stuff a long time ago when it was a lot less expensive. They have good prices on Cleco fasteners and clamps. I use them for a lot of different purposes. Working sheet metal is one. I use the little clamps to hold headliners to the pinch welds when installing them. They make shop life a little easier.
Old 06-03-2023, 07:06 PM   #8
bobbader
Brattons has them. Brattons.com. search "Rivets" and scroll down.
bobbader is offline   Reply With Quote
Old 06-03-2023, 08:37 PM   #9
Martinbuilt
Thanks for all the leads. Should be set, no matter what i take apart.
Old 06-04-2023, 01:34 PM   #10
Hans hendrik
keep in mind you need a lot of heat and of course the tools on both sides of the rivet
Hans hendrik is offline   Reply With Quote
