Old 05-27-2023, 12:53 PM   #1
Keith
Default Reaming Axle Spindle to fit King Pin
I just installed new bushings in my axle spindle and reamed with a brand new reamer from one of the suppliers. New King Pin is extremely tight starts to go but then gets very tight. Any tricks after reaming to make a slip fit.
Keith
Keith
Keith is offline   Reply With Quote
Old 05-27-2023, 01:30 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Reaming Axle Spindle to fit King Pin
Take them to a local machine shop and hone them to fit.
Paul in CT
Old 05-27-2023, 01:44 PM   #3
Martinbuilt
I had one like that, the pin was slightly bent.
Maybe check that as well.
Martinbuilt is offline   Reply With Quote
Old 05-27-2023, 01:47 PM   #4
Fhane
Fhane's Avatar
Ream again. Never turn a reamer backwards. Use a good cutting oil for reaming. Make sure reamed hole and king pin are absolutely spotless. Now try it. If sill a problem call the vender. Hopefully you bought the reamer and kingpins from the same vender.
Fhane is offline   Reply With Quote
Old 05-27-2023, 01:53 PM   #5
Keith
thanks to all will run the ream through again
Keith
Keith
Old 05-27-2023, 03:45 PM   #6
Jim/GA
Jim/GA's Avatar
I ran across the following video about reaming spindle bolt bushings a few days ago and I thought it was very well done.
https://youtu.be/q6H9VL22NNc
Lots of cutting oil, never turn the reamer in the opposite direction, clean the reamer often, and gently take a second pass through the bushings.
This guy does it outdoors on an old picnic table!
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 05-27-2023, 06:48 PM   #7
Synchro909
Synchro909's Avatar
That's not a bad video but I saw something VERY wrong as he reassembled the king pin. A hammer should never be used on the head of the cotter pin - pulling it in with the nut is quite enough. Hammering is very likely to stretch the eye in the end of the axle, ruining it. I've seen it done too many times.
Back to the OP's question. If the king pin bushes are too tight, the car will be impossible to control. I use an adjustable reamer and stop just short of finished size. I then use the unworn part of the old king pin (the part that was in the axle eye) with some valve lapping paste on it and lap to a nice fit. After THOROUGHLY cleaning the bushes, add a drop of oil and check for a good fit. A good fit is when you can push the pin through the bushes with your thumb without straining.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 05-28-2023, 10:35 AM   #8
Keith
Found the cause for the King Pin binding when fully inserted into the spindle. There is a slight taper ~ 0.001" on the king pin diameter, larger at the closed end toward the half ball end. Used 1200 grit emery while spinning the king pin did the trick. I also found the grease groove that runs along the length of the king pin was sharp. I stoned it and now the fit is good.
Keith
Keith
Old 05-28-2023, 11:07 AM   #9
Phil Brown
Phil Brown's Avatar
Originally Posted by Keith View Post
Found the cause for the King Pin binding when fully inserted into the spindle. There is a slight taper ~ 0.001" on the kingpin diameter, larger at the closed end toward the half-ball end. Using 1200 grit emery while spinning the kingpin did the trick. I also found the grease groove that runs along the length of the kingpin sharp. I stoned it and now the fit is good.
Keith
Happy that you got the problem resolved, but sad that something that needs tolerances as tight as a kingpin can not be held in the manufacturing
Care to share the brand of these inferior parts for others to watch out for ?
Phil Brown is offline   Reply With Quote
Old 05-29-2023, 05:22 AM   #10
Keith
I purchased them a few years back and were from either Snyder or Bratton, my guess is that when they were ground between centers by the mfg. and that the wheel was dressed or worn with a slight taper on the side which comes up against the half round cut end and flange. Keith
Keith
Old 05-29-2023, 08:30 AM   #11
CT Jack
CT Jack's Avatar
You need to follow Keith's suggestions. Measure, measure. Reamers are usually very uniform in diameter over their length. As he suggests king pins can contain taper over their length. If you accurately measure the king pin diameter at several places along it's length you will probably notice a small change. King pins which are hardened steel are usually machined by grinding. As the grinding wheel moves from one end of the pin to other it wears causing less material to removed toward the end of the pin. If the machinist doesn't compensate for this condition this is how the pin diameter becomes tapered. In general, the amount of taper is usually less than .0005" which is enough to create a no-go condition. Polishing the tapered area of the pin with a fine emery type abrasive usually fixes the problem. Repeatedly running a hand controlled reamer through the hole is not a good idea as it increases the chances of changing the precision of the newly cut diameter.
CT Jack is offline   Reply With Quote
Old 05-29-2023, 10:55 PM   #12
Dodge
If their a little tight I use a ball hone for that last little bit.
Dodge is offline   Reply With Quote
Old 05-31-2023, 01:03 PM   #13
alchemy
alchemy's Avatar
I disagree. I have snapped the threaded portion off a kingpin lock when trying to pull it in. Now I always take a punch and hammer to tap the lock into position. I’m not whamming hard on the thing, but I make sure it’s very snug in there. I am never hitting the axle with the punch or hammer.
alchemy is offline   Reply With Quote
Old 05-31-2023, 08:04 PM   #14
Synchro909
Synchro909's Avatar
Did you line up the king pin in the hole by eye before inserting the cotter pin? I put the pin in the hole, then turn the king pin by hand and set it at the middle of the range to allow the cotter pins to slide in easily. The brake actuating arm can make that a bit challenging but the further the pin goes in, the less it will turn.
Old 06-01-2023, 04:32 AM   #15
Bruce of MN
Bruce of MN's Avatar
I had a tough time inserting my cotter and wished I had tried it first without the kingpin to check the fit.
Bruce of MN is offline   Reply With Quote
