Old 05-25-2023, 10:50 AM   #1
Steve Staysko
Steve Staysko's Avatar
Default Nice 34 Roadster
https://barnfinds.com/1st-place-awar...ford-roadster/
Steve Staysko is offline   Reply With Quote
Old 05-25-2023, 10:54 AM   #2
petehoovie
petehoovie's Avatar
Default Re: Nice 34 Roadster
Originally Posted by Steve Staysko View Post
Old 05-25-2023, 12:04 PM   #3
deuce lover
deuce lover's Avatar
Are the judging standards of the AACA as stringent as the Early Ford V8 Club's?
deuce lover is offline   Reply With Quote
Old 05-25-2023, 12:16 PM   #4
petehoovie
petehoovie's Avatar
Look at this one > https://www.hemmings.com/auction/193...&utm_campaign=
The "POWERTRAIN" description is entertaining...
Old 05-25-2023, 12:36 PM   #5
Tim Ayers
The seller reports that the Ford will overheat if driven when the temperature is above 70. The engine bay presents as generally clean, with what appears to be chromed aftermarket water pipes.
Oh lord.... So it can only be driven if you live in Alaska?
Tim Ayers is online now   Reply With Quote
Old 05-25-2023, 05:29 PM   #6
Kube
Kube's Avatar
AACA judges on the quality of the restoration, NOT the correctness.
I'd never placed much "stock" in a AACA awarded car as they can be nice in appearance but so very incorrect in so many ways.
I am far from being a '34 expert but can spot many incorrect things on that '34 roadster without much effort. So, if I can spot "many", just how many will a true '34 expert (Dave, ya out there?) spot?
Old 05-25-2023, 05:55 PM   #7
Bored&Stroked
Bored&Stroked's Avatar
That 32 surely has a few 'hacks' on it and things that are not original. BUT, if it is an actual Ford body and doesn't have any rust issues or crappy body work, it wasn't a bad price for $42K.
It probably needs a new engine and some other mods, but it would make a good hotrod start. Try to get to this level starting out with a Brookville body . . . you'll be far over $40K (depending on who is doing the work).
Old 05-25-2023, 06:03 PM   #8
Tim Ayers
Agreed, but all that you mentioned must be be inspected and confirmed. These on-line auctions can hamper a proper inspection.
Using all the other "issues" as a gauge, I'd assume there are some sins. lurking underneath.
Old 05-25-2023, 06:53 PM   #9
DavidG
DavidG's Avatar
I can't see much of the '34 given all of the ads, but about all the stands out in the few photos I could view are the wheel trim rings (not Ford) and the finish on the grille bars.
The '32 roadster? Now that's an entirely different story.
Old 05-25-2023, 07:00 PM   #10
Kube
Kube's Avatar
re the 34:
Single side whites?
Gas tank finish?
Old 05-25-2023, 07:15 PM   #11
DavidG
DavidG's Avatar
Of course, the single side WSW and I wonder about the color of the top, it could be faded T-14 or maybe not. I could not find a photo with the gas tank showing, only six photos in total. Tough to sell anything for 100K with only that much showing.
Old 05-25-2023, 07:30 PM   #12
petehoovie
petehoovie's Avatar
Old 05-25-2023, 07:32 PM   #13
petehoovie
petehoovie's Avatar
26 Photos here > https://barnfinds.com/classifieds/19...-deluxe-rdstr/
Gas Tank
Old 05-25-2023, 07:38 PM   #14
DavidG
DavidG's Avatar
I could be going blind, but my opthalmologist would claim that isn't so. If you look closely at the interior photos of the '32 it appears that the wood back belt does not tuck down into raised pockets in the upper quarter panels, but rather sits on top of the upper quarter panels, a sure sign it is not an original body but one made much more recently in Ohio. The other tell tale sign is that we can see far too much of the binding head screws attaching the dash to the cowl, which is another Brookville giveaway.
Forty K seems a bit high for a repro body and a tired 59A engine.
Old 05-25-2023, 07:39 PM   #15
Kube
Kube's Avatar
David, I'd never even think to pretend I knew a thousandth of what you do in regard to '34 Fords.
The gas tank appears to be a Drake with Drake's silver powder finish. Wrong drain plug / wrong finish on the plug.
When I read an ad that states clearly the car was "restored to factory correct specs in concourse quality" and it takes me but a minute to find a number of inconsistencies, well, that leads me to believe the seller either doesn't know any better (oh oh!) or the seller is BS'n a bit too much (a bigger OH OH!).
The top is stated to be tan. Um, "restored to factory correct specs..."?
It was also stated that the year of restoration was unknown (no documents?) and having been driven little, the car remains in concourse condition.
The supposed few miles it was driven were apparently laid down in the desert judging by the dust / dirt on the undercarriage.
Perhaps the concourse referenced is the local McDonalds, Wednesday evening?
Old 05-25-2023, 07:44 PM   #16
DavidG
DavidG's Avatar
Pete,
Thanks for providing the photos of the '34.
Mike,
You're sure right about the gas tank. Still, far too few photos for a $100 K car. What about the floor? The wood graining is suspicious and that's poor workmanship to have that stitching showing above the dash. It's easy to avoid.
Old 05-25-2023, 07:52 PM   #17
DavidG
DavidG's Avatar
Two more glitches on the '34: spare tire bracket should be black and seat sight shields should be color of upholstery, not body color.
It looks to be a very nice car, just not a $100 K example, IMO.
Old 05-26-2023, 12:16 AM   #18
restoman
wrong one piece sparkplugs
restoman is offline   Reply With Quote
Old 05-26-2023, 12:51 AM   #19
deuce lover
Kube, Thank you for that response.Sheldon
Old 05-26-2023, 08:01 AM   #20
rockfla
rockfla's Avatar
Sheldon
We were told by a group of AACA judges in SE Regional show in Gainesville FL "there is nothing correct on this car" about our German 32!!! AND It won a National First Place in 1967 in Fort Lauderdale FL WAY more incorrect than it is now, Ie 34 engine and all the accompanying ad ons, etc etc !!!!
