Old 04-19-2023, 11:30 PM   #1
oldspert
oldspert's Avatar
Default painting floorboard
I did a search and found lots of different opinions on painting the floor boards. My car will never be judged but I do not want bare plywood either, so it will be painted black, since I have a reproduction rubber floor mat, it will not show anyway.
oldspert is offline   Reply With Quote
Old 04-20-2023, 09:02 AM   #2
mcgarrett
Default Re: painting floorboard
Yep, nothing wrong with painting black with a good enamel. Helps keep moisture/rain from doing its dirty-work.
mcgarrett is offline   Reply With Quote
Old 04-20-2023, 09:40 AM   #3
Ed in Maine
There could be many suggestions on this topic. In the past I have used 2 coats of Ebony Stain and three coats of spar varnish (sanded between coats). While you are at it why not add a heat baffle to the underside of the floor board to keep the exhaust pipe heat out of the car. My heat baffle is a small sheet of aluminum from Home Depot and 1 in. stand offs to provide an air space between the aluminum sheet and the plywood. Have fun with it. Ed
Ed in Maine is offline   Reply With Quote
Old 04-20-2023, 09:45 AM   #4
Aretino
Aretino's Avatar
Used engine oil works great and offers the added bonus as a air freshener.
Aretino is offline   Reply With Quote
Old 04-20-2023, 10:11 AM   #5
Will N
Will N's Avatar
Originals were treated with a black preservative. I don't think I ever saw this anywhere, but I think a common preservative back then was creosote.
Will N is offline   Reply With Quote
Old 04-20-2023, 10:48 AM   #6
Oldbluoval
Oldbluoval's Avatar
I think it was called Gilsonite which is a asphaltum product
Not sure floorboards were treated with that …..just painted
Oldbluoval is offline   Reply With Quote
Old 04-20-2023, 12:44 PM   #7
David in San Antonio
David in San Antonio's Avatar
Arentino - Before coating the floorboards with used crankcase oil should I add some Marvel Mystery Oil? If so, how much?
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 04-20-2023, 02:01 PM   #8
ModelA29
ModelA29's Avatar
I've wondered about using some of the newer heat reflective coatings.
https://insulationcoatings.com.au/wh...ation-coating/
ModelA29 is offline   Reply With Quote
Old 04-20-2023, 02:54 PM   #9
Oldbluoval
Oldbluoval's Avatar
Sorry but used motor oil is not an “air freshener “ to me.
U must have some really bad stench in your car!!
Cadaver left there a few weeks?!!
Old 04-20-2023, 03:18 PM   #10
mcgarrett
Looks like this thread on the information super-highway has taken a dirt road!
Old 04-20-2023, 03:46 PM   #11
Werner
Werner's Avatar
Used engine oil always contains PCBs and is therefore carcinogenic!
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 04-20-2023, 06:46 PM   #12
Oldbluoval
Oldbluoval's Avatar
Well they used to put waste oil on dirt roads…..before EPA
Does that count??
Old 04-20-2023, 08:32 PM   #13
MickyD
MickyD's Avatar
Crude oil is still used on roads but in asphalt. Go figure.
MickyD is offline   Reply With Quote
Old 04-20-2023, 11:43 PM   #14
Bill G
Bill G's Avatar
Interesting.... I did all of that with mine! Exactly.
Bill G is offline   Reply With Quote
Old 04-21-2023, 10:13 AM   #15
31Tudor
31Tudor's Avatar
I used Minwax, stain, True Black. It allows the grain to show, simulating the original look.
31Tudor is offline   Reply With Quote
Old 04-21-2023, 12:39 PM   #16
31Cabriolet68-C
31Cabriolet68-C's Avatar
Ditto recommending Minwax...
Stain is best approach.
"Wood Hates Paint"!
31Cabriolet68-C is offline   Reply With Quote
Old 04-25-2023, 01:44 PM   #17
JayJay
A little late on the uptake, but I too do a black wood stain followed by clear top coat.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 04-25-2023, 04:20 PM   #18
Tacoma Bob
Tacoma Bob's Avatar
Minwax Spanish Brown and top coated with spray Helmsman Spar Varnish. Spanish Brown is basically black. Came out nice.
Tacoma Bob is offline   Reply With Quote
Old 04-26-2023, 11:20 AM   #19
burner31
burner31's Avatar
Use marine board, and a sealing stain of your choice...done and done
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
