Old 03-22-2023, 09:50 AM   #1
Dkrahn
Default 5.5 high compression head
With the standard head on my '29 pickup I had autolite 3076 spark plugs. Should I move to different plugs with HC head?
Dkrahn is offline   Reply With Quote
Old 03-22-2023, 10:24 AM   #2
Flathead
Flathead's Avatar
Default Re: 5.5 high compression head
I use stock A plugs on my 5.5 with no problems.
Flathead is offline   Reply With Quote
Old 03-22-2023, 11:19 AM   #3
Jim Brierley
Yes, stock. You may want to not run as much spark advance.
Jim Brierley is offline   Reply With Quote
Old 03-22-2023, 11:54 AM   #4
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I have very good results with Champion W16Y plugs in my 5.5.
Dick M is offline   Reply With Quote
Old 03-22-2023, 03:32 PM   #5
Bruce of MN
Bruce of MN's Avatar
I limit the advamce travel with this.
Bruce of MN is offline   Reply With Quote
Old 03-22-2023, 04:05 PM   #6
goldie
Has anyone used a Champion W89D plug? A local "A expert" said to use this plug, used by hill-climb racers? It is a much longer electrode plug for industrial applications, not Model A. I have put about 2000 miles on them so far so good.
goldie is offline   Reply With Quote
Old 03-22-2023, 04:39 PM   #7
The Master Cylinder
The Master Cylinder's Avatar
By the length of porcelain on that plug I would think it would be pretty hot. How does it read?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 03-22-2023, 05:06 PM   #8
goldie
The plug color looks normal to me, runs fine with Snyder high compression head
