Old 03-13-2023, 12:07 PM   #1
AnthonyG
AnthonyG's Avatar
Question ‘47 rear brake cylinder question
Hi all, started putting used rear ‘47 brake backing plates on my ‘35, part of the Hydraulic conversion, & decided to change the rear cylinders before installing. I see the cylinders for a car are significantly more expensive by a factor of 5 than for a pickup? I’m cheap LOL so can the car brake cylinders b swapped out for the less expensive PU truck cylinders? $20 vs $120
Nomad
AnthonyG is offline   Reply With Quote
