Old 02-28-2023, 09:04 AM   #1
[email protected]
rvye@roadrunner.com's Avatar
Default Model a head on model b engine
Will a model a head fit on a model B engine
rvye@roadrunner.com is offline   Reply With Quote
Old 02-28-2023, 09:41 AM   #2
emf
emf's Avatar
Default Re: Model a head on model b engine
yes, use the correct head gasket.
emf is offline   Reply With Quote
Old 02-28-2023, 10:15 AM   #3
MAG
MAG's Avatar
Don't forget to plug the "steam" holes.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 02-28-2023, 05:35 PM   #4
Synchro909
Synchro909's Avatar
I have had an A head on a B engine for over a decade without plugging those holes. I was told I should but couldn't see the point. Maybe I did the wrong thing but it has been fine. What reasons were given to you? (Not being confrontational)
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 02-28-2023, 05:47 PM   #5
Bob C
If you use an A head gasket with a B head or block it may not adequately cover the holes.
Old 02-28-2023, 06:59 PM   #6
31a
i have some B heads if you want one also B water pumps
31a is offline   Reply With Quote
Old 03-01-2023, 08:22 AM   #7
Joe K
Joe K's Avatar
I think its a matter of the "distance" between the hole and the nearest "free edge" of the gasket. Everywhere else around the head the distance is "standard" and (should but commonly doesn't) have the "bound edge" of the copper cover to add to the gasket compression.
The "commonly doesn't" would be the "aftermarket" modern gaskets. For many high compression heads these are the recommended gaskets.
I tend to agree though. Not necessary to plug the holes if you use a quality gasket.
The literature for the original Gordon-Smith compressor heads - based on a Model B head at least the part on cylinders 1 and 4 - don't mention the holes or their plugging. But that is a "different" and perhaps even more challenging application.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 03-01-2023, 09:55 AM   #8
MAG
MAG's Avatar
Agree with posts 5 &7. Had a couple in my shop that leaked using Best Copper gaskets. Plugging the holes stopped the leaks. Agree, it is not necessary to plug the holes unless the gasket leaks. (Smile)
Old 03-01-2023, 12:58 PM   #9
Bob Bidonde
Bob Bidonde's Avatar
This slide should help:
Bob Bidonde
Old 03-01-2023, 02:21 PM   #10
Jim Brierley
The 4 holes down the center-line of the block re the ones that should be plugged. They need to be plugged flush with the block surface to support the gasket.
Jim Brierley is offline   Reply With Quote
Old 03-02-2023, 10:57 AM   #11
the cooch
the cooch's Avatar
High compression Model A head allows modern, “leakless” A water pump that is cheaper and easier to get than reworking or buying a B motor pump. Not a huge difference but keeping the B head does add that factor. Just went through it….-Chris in Boulder
File Type: jpg 67EFC69D-579C-430B-93BE-13E5C11A632E.jpg (92.8 KB, 48 views)
the cooch is offline   Reply With Quote
Old 08-10-2024, 10:31 PM   #12
Leoneidas
Leoneidas's Avatar
Do you still have this available? I just removed my head due to some overheating issues to find my block filled with stop leak from a precious owner. Would like to upgrade while I'm at this stage and looking to assemble asap.
Please let me know.
Thank you in advance.
Leoneidas is offline   Reply With Quote
Old 08-11-2024, 12:06 PM   #13
rackops
rackops's Avatar
Please let me know.
If you can't get one from the previous poster, I have several non-restored B heads I'd like to get rid of.
I have a diamond B block and plan on replacing the B head with an A head for looks, sometime in September. All of my B water pumps are spoken for (most are already on their way to Australia) but I will also clear out my stash of B heads as well.
Member, MARC
Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity" and a 1931 Victoria "Katie"
Former owner, 1929 Phaeton, 1929 Fordor
rackops is offline   Reply With Quote
