#1 |
Is there a Ford Barner out there who could fabricate a bracket (see photo below..I would need the black bracket with 3 holes that connects to the head at the bottom and holds the spin on oil filter adapter assembly at the top). I would most definitely pay for your labor and materials!!
Looks like these conversion kits are no longer available… As always, thank you in advance! ~SteveD8421EEE-7220-46A3-B52C-69FB228EE3D6.jpg Last edited by 38convsedan; 02-26-2023 at 02:00 PM. |
#2 |
Steve, I’d like to discourage you from that installation for the reason that an original type of bypass filter is constructed without concern for needed pressure and volume as a full flow system requires today. That means that a modern spin on filter allows larger particulates to pass, and has a built in pressure relief, both features ensuring the pressure and volume required by a bypass system. This system, of course, would be preferable if you have converted to the 95% full flow, but not for the original system.
Alan |
#3 |
I believe this is designed for the original 8BA bypass oiling system and as such uses a filter matched to the original flow rate of the canister design.
#4 |
