Old 02-23-2023, 06:50 PM   #1
AnthonyG
AnthonyG's Avatar
Default Coolant blew out overflow on radiator?
8BA/ flushed engine, put new antifreeze green, while idling during timing & carbs adjust it decided to blow out about a quart or so of new coolant. I have temp gauges on both banks & it wasn’t running hot, 185 right side 195 left side. After blowing out the quart+ it stopped. I let it continue running & temp stayed about the same. I’m delinquent in flushing & changing , been a few years. Engine has 4” bore Merc crank, domed pistons, 2 X 2 Holley 94, oversize valves, Mallory e-Dist. & Isky cam.
I vaguely remember a post & thread a few years ago saying if engine & radiator r over filled it should seek its own level ( I filled to about a 1/2 “ below top of rad. Tank)? While it didn’t happen a few years ago that I remember I’m
Thinking that’s Probly what happened?
Nomad
AnthonyG is offline   Reply With Quote
