Old 02-20-2023, 01:07 PM   #1
jiw1
Default 16' inner tubes
i picked up some used 600x16 tires and plan on mounting them on 16"x4 1/2"rims with 600x16" tractor (implement tires) inner tubes, will this work?
jiw1 is offline   Reply With Quote
Old 02-20-2023, 03:25 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: 16' inner tubes
I don't see why not.
Old 02-21-2023, 07:58 AM   #3
GB SISSON
GB SISSON's Avatar
I do a lot of tire and tube work and have learned to buy tubes only from agricultural outlets as they are thicker material. I have been working on a balloon tire bike project. Ordered 2 tires and tubes. One tube blew up at about 30 lbs so I put a patch on one of the old tubes that came from a tire marked 'A war tire-made from regenerated rubber'. It was maybe twice as thick and is holding it's own.
Old 02-21-2023, 04:21 PM   #4
Brian
Brian's Avatar
I always use tractor tubes; they are of heavier material, and the valve stems are correct size for early Ford rims
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 02-21-2023, 08:28 PM   #5
Jeff/Illinois
Jeff/Illinois's Avatar
That is exactly what our local Farm Supply tire shop replaced a tube in our '36 PU with. Going on two years ago. A farm implement tube. And that sucker is a LOT heavier made tube than the car type tube that came out!
Jeff/Illinois is offline   Reply With Quote
