Old 02-16-2023, 03:41 PM   #1
1931 flamingo
1931 flamingo's Avatar
Default Dual carbs
Stupid question.
How do you get the back bolt out? Is there a special wrench or what have others done??
Paul in CT
It's the front carb on an Almquist manifold.
Old 02-17-2023, 08:08 AM   #2
Tim Ayers
Default Re: Dual carbs
Paul:
Which back bolt are you referring to? The one center mounting stud under the carb? If so, just a box wrench will do the job.
Tim Ayers is online now   Reply With Quote
Old 02-17-2023, 10:25 AM   #3
19Fordy
19Fordy's Avatar
Photo please of your carbs/intake.
Old 02-17-2023, 10:37 AM   #4
solidaxle
solidaxle's Avatar
You're probably trying to avoid taking off both carbs to get to the one nut. I have the same scenario. There's just no avoiding it.
solidaxle is offline   Reply With Quote
Old 02-17-2023, 12:52 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
On Stromberg's it easier to just remove the three screws hold the bodies to the base. Thus leaving the throttle plate base on the intake. Now if you need to remove the base you can easily get to the mounting hardware.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 02-17-2023, 01:17 PM   #6
1931 flamingo
Thanks Ron, I'll try that.
Paul
