Old 01-17-2023, 07:14 PM   #1
Harlow
Default 53 ford customline windshield motor replace
How do one replace the windshield motor on a 53 ford car
Harlow is offline   Reply With Quote
Old 01-17-2023, 08:04 PM   #2
paul2748
paul2748's Avatar
Default Re: 53 ford customline windshield motor replace
Best to remove the front seat and give you lots of room to move around. Not an especially nice job with the dash in. Did it my 54 (went to electric wipers). If you can take a picture of the assembly if it's still in (before you remove it)
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-18-2023, 04:59 PM   #3
mfirth
The motor in my 53 didn't work well till I gave it a dose auto trans fluid. Let it set after manually exercising it. Just a small amount will swell the paddle seal & mine worked fairly good.
mfirth is offline   Reply With Quote
Old 01-18-2023, 08:02 PM   #4
paul2748
paul2748's Avatar
Dot 3 brake fluid works as well
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-19-2023, 01:32 AM   #5
Newc
Newc's Avatar
Easier with radio, clock, ect removed. Try the lube suggestions first. Newc
