Old 12-31-2022, 03:01 PM   #1
burly
burly's Avatar
Default Pressure Plate release lever stiffness?
Guys just mounted 39 tranny to fresh rebuild 59A, Weber flywheel. Rebuilt 9" clutch, pressure plate and new throw out. Slid pipe over clutch shaft arm and push forward but pressure plate release levers didn't budge after throw out made contact. Might supposed to be that stiff? I didn't want to push hard enough to damage anything. Appreciate your thoughts. Don't want to install and have to jerk back out.
burly is offline   Reply With Quote
Old 12-31-2022, 06:59 PM   #2
cas3
Default Re: Pressure Plate release lever stiffness?
I don't think it should be that hard to move. The fingers had to move as you tightened up the PP, can you watch thru the hole on top ?
Old 12-31-2022, 07:14 PM   #3
J Franklin
J Franklin's Avatar
How much force are you generating to do the job?
Old 12-31-2022, 07:15 PM   #4
Mart
Mart's Avatar
Correct 59A type pressure plate? Fingers not fouling the input or front snout?
Remove cover and have a good look.
You need about a 2 ft long lever to do it without struggling.
Old 01-02-2023, 01:31 PM   #5
1931 flamingo
1931 flamingo's Avatar
Are the fingers adjusted properly??
Paul in CT
Old 01-02-2023, 04:21 PM   #6
burly
burly's Avatar
Thanks fellas! Just didn't push quite hard enough.
