#1 |
Anyone have a recommendation for a wiring harness maker for a 31 coupe??
Bob from Northport Northport, Michigan |
#2 |
Sacramento Vintage.
https://www.vintageford.com/sect_main.cfm?Line=main |
#3 |
Try Bauer Electronics in Bend Oregon. They have built 2 harness for me. give them 10 stars.. Phone # (541) 389-7755 Rick
#4 |
Tyree Harris is another good source. 805-556-5200. He is in Bumpass, VA.
1910 Model T Touring 1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
#5 |
The harness for my '31 Coupe from Brattons was fine.
#6 |
https://www.ynzyesterdaysparts.com/ They offer additional options such as turn signal add on wiring, or not depending on your needs.
Making the simple complicated for over 30 years. |
#7 |
I ordered from Tyree recently. Great service and a good part, too. I like supporting the little guy, the independent. My family survived on a small business income.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
#8 |
Tyree Harris is the man to go to.
#9 |
Bauer Electronics fabricates them for several different parts sources. They are decent quality and come with good instruction sheets. All model A harnesses are pretty much the same with exception to some AA trucks due to frame lengths and tail light distance from the light switch. Some have better light switch terminal discs than others. Rhode Island Wire likely makes up the best quality harness but they will likely be a bit more expensive too. They coat the fabric wire covering with a clear coat to keep the color longer Bauer doesn't coat theirs.
#10 |
Bratton makes a very good harness, with all the connector ends being soldered, as opposed to Snyders that has clip on ends and no solder in the harness.
#11 |
For a show quality harness you cannot beat Tyree Harris. He has done two of them for me.
#12 |
The Bratton harness is exceptional!
#13 |
I had an excellent experience with Tyree Harris (also) and was happy I gave him a call. He also custom-made a length I was missing as well.
