Old 11-13-2022, 09:15 AM   #1
ModelAArmy
Default Door alignment
As a new member of the A community, I am learning so much from this forum and the Model A club I joined. I have researched door alignment and am confused as to what I should do to correct my problem. The female dovetail bumper on both of my doors does not strike the male dovetail correctly. It strikes about a quarter inch too low. It seems that I need to raise the end of the door. How do I do this. Thanks
Tom in Texas
1931 Coupe
ModelAArmy is offline   Reply With Quote
Old 11-13-2022, 09:31 AM   #2
jw hash
jw hash's Avatar
Default Re: Door alignment
first of all, what body style are you working on? does the front edge of the door line up with the cowl? if not, it could be in the hinges if they do you can tip the cowl by removing the front body bolts and adding a shim under the rear of the cowl. reinstall the bolts. it doesn`t take much.
jw hash is offline   Reply With Quote
Old 11-13-2022, 09:40 AM   #3
BillCNC
BillCNC's Avatar
The Modelaclub.com USED to have this information readily available in a Tips section on their site, but for some asinine reasoning, it's now behind a $30.00 pay wall very recently. You cant get to the tips section without feeding the greed.
Old Link: https://modelaclub.com/archives/tech-tips/1211
Nothing like hording information for a 95-91 year old car could make a club more irrelevant in my eye's.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 11-13-2022, 09:55 AM   #4
BillCNC
BillCNC's Avatar
Haha,
Turns out I copied the info behind the firewall for reading off line a while back (closed car PDF), so here you go.
Also, here is information on body alignment that will be helpful.
Regards
Bill
Old 11-13-2022, 10:42 AM   #5
ModelAArmy
Thanks for this info. I first want to inspect hinges for problem. In the instructions it said to check this hinge gap.
Straighten door hinges. Door hinges are often bent. Straighten and adjust to obtain an even gap at each hinge pillar measuring 1/16′′ to 3/32′′. No other course of action will resolve this problem.
How and where exactly is this gap measured. Thanks
Tom in Texas
1931 Coupe
Old 11-13-2022, 11:01 AM   #6
BillCNC
BillCNC's Avatar
The gap is between the front of the door to the cowl / windshield pillar.
I have found less bent hinges vs worn top hinge pins. The holes are worn out letting the rear of the door sag. They make oversized pins to correct this. You might want to take the rear of the door with it slightly open and raise the latch end up and down. How much movement is there?
Regards
Bill
