#1 |
I recently received my new clutch kit for my 39 style trans. It came complete with a new clutch release hub and bearing. However it’s very different from the original and I’m wondering if I should run the original hub or this new style?
#2 |
Use the original hub but replace the bearing with one that matches your original. The release hub you received is not correct at all never seen one like that for the early Ford transmission.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#3 |
Thank you, I hadn’t either. Not sure what this is for. Clutch and pressure plate look correct but this threw me for a loop. Thank you.
#4 | |
#5 |
Where/who did you get the parts from??
Paul in CT |
#6 |
#7 |
#8 |
Interesting. Have you checked to see if it happens to fit the transmission and clutch fork? I'm just curious.
Also, is this a LONG style clutch, Borg & Beck, or Diaphragm? Depending on the clutch setup, it may or may not work and it may also be important to understand the LENGTH the clutch requires from the fork front to the PP fingers . . . is this length different with this TO bearing versus the typical ones we're used too? |
#9 |
To use it, you would need to add someway for the spring to attach to it. Otherwise, it would have no way to retract accept to use your foot under the pedal.
#10 |
Would that be for a fork type clutch fork ? He said it is for a 239 .
#11 |
#12 |
I am betting the part number of the kit you bought is 07-516.. If so trash the hub and bearing and buy the appropriate
The kit you bought, again betting I am right on the part number has a great disc, but the pressure plate is marginal but you should be ok.. The hub and bearing WILL NOT WORK!! |
#13 |
#14 | |
#15 |
Will this help?
https://www.youtube.com/watch?v=XkEVJoA4O-A |
