Old 03-19-2011, 07:17 AM   #1
Jack Innes
Jack Innes's Avatar
Default MAPP gas torches
I just found this on an other site & thought we all should be aware of the possible dangers with these torches. I just bought a second one & find it extremely useful but it obviously deserves to be treated carefully.
Check the following link - (Caution there are some pictures you may not want to see!)
http://www.bernzomaticinjuries.com/bernz_002.html
This seems a legitimate problem & not the work of some nut exposing an obscure possibility.
Jack Innes is offline   Reply With Quote
Old 03-21-2011, 10:26 PM   #2
b ramsey
Default Re: MAPP gas torches
wow! thanks! i have one of those rolling around in the back of my worktruck! im posting that up in the shop i work out of for sure!
b ramsey is offline   Reply With Quote
Old 03-22-2011, 06:53 AM   #3
supergnat
supergnat's Avatar
Wow, that is scary. I use the torch tip with the flexible hose but that kit came with a belt clip which holds the tank to your belt. I would hate to see what would happen if the tank neck broke while on my belt.
supergnat is offline   Reply With Quote
Old 03-22-2011, 03:43 PM   #4
Kohnke Rebabbitting
Thanks Jack, Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 03-22-2011, 04:24 PM   #5
FRANK PKNY
FRANK PKNY's Avatar
Scary!!
FRANK PKNY is offline   Reply With Quote
Old 03-22-2011, 10:18 PM   #6
Teltruck
Teltruck's Avatar
Thanks Jack!
Teltruck
Teltruck is offline   Reply With Quote
Old 03-23-2011, 11:25 AM   #7
joncrane
Is it just the mapp gas or all of the torch/propane cylinders?
joncrane is offline   Reply With Quote
Old 03-23-2011, 11:32 AM   #8
CharlieB
CharlieB's Avatar
I would assume the dangers relate to both types. Never heard about this before. It's a wake-up call for sure.
CharlieB is offline   Reply With Quote
Old 03-23-2011, 12:56 PM   #9
Doug Money
Doug Money's Avatar
All the litigations were filed between the years 2004 and 2008. We know of no litigation involving propane gas. All breached cylinders known to date contained MAPP gas. As of April 30, 2008 "MAPP" was no longer produced, and Worthington replaced it with "MAP" gas under the Worthington label. It appears the cylinders continue to be designed with deficient joints, though whether or not the added problem of corrosion will exist with the new gas is not known at this time. Worthington disclosed it sold about 21 million units over a two or three year period, apparently between the years 2005 and 2008. Many of the "MAPP" cylinders remain on the market as of the date of this publication.
Doug Money is offline   Reply With Quote
