Old 08-25-2022, 07:04 PM   #1
corvette8n
corvette8n's Avatar
Default Canadian guys lower their ‘41 Merc rear
https://youtu.be/tnB-LtZh_Zc
I know this was talked about lately.
Old 08-26-2022, 07:18 AM   #2
richard crow
Default Re: Canadian guys lower their ‘41 Merc rear
the more drop you add the more the car sways left to right looks good but spoils the ride
richard crow is offline   Reply With Quote
Old 08-27-2022, 07:16 AM   #3
1931 flamingo
1931 flamingo's Avatar
Funny how since before the 60's up and including now how much money has been spent lowering the front.................
Paul in CT
Old 08-28-2022, 08:06 AM   #4
fortyonerag
fortyonerag's Avatar
Without some kind of rear track rod it'll handle like a Labrador on linoleum. My 41 did. Not that I was doing any fancy driving, but a gusty crosswind could get very sporty.
Too much sideways movement from long shackles and you will scrub into the sidewall on the rear tyres when cornering. Don't ask.
Eventually I reversed the eyes and de-arched the springs. Guess I just had to learn he hard way. Nice spring spreader BTW.
fortyonerag is offline   Reply With Quote
Old 08-29-2022, 01:06 AM   #5
AKCJ
My new to me 37 coupe came with the super long shackles on the front causing the axle to be right down on the bump stops. Not good.
I ended up building a spring spreader to remove them. I cut off two inches and made new (square) holes. Would have been worth it to buy new but I didn’t know the holes were square before I started.
Typical for me - a half day project turns in to a two day project.
AKCJ is offline   Reply With Quote
Old 08-29-2022, 08:07 AM   #6
tubman
tubman's Avatar
I was kind of afraid this was done the way a '40 Ford I had years ago was done. With a torch. The spring had almost a 90 degree bend on each end. I don't think it would have had a very good ride, but I never ran it that way. I replaced the torched spring with one fresh from the junkyard. Yep, used long shackles (mainly because you didn't need a spring spreader to install it.)
