Old 08-22-2022, 02:46 PM   #1
randy993
randy993's Avatar
Default What would cause my right front to be lower?
Hello all,
What would cause my right front area on my truck to be lower? I can have it on level ground and put a four foot level across the bumper supports and the right side is about an inch lower. I know this is not a very scientific way of measuring but I have always noticed it sitting like this. You can see in the photo. It has all of the stock suspension. Thanks
File Type: jpg 52933E62-56AA-44DF-A22A-50D858FB7053.jpg (63.6 KB, 300 views)
randy993 is offline   Reply With Quote
Old 08-22-2022, 02:54 PM   #2
deuce lover
deuce lover's Avatar
Default Re: What would cause my right front to be lower?
The spring or a twist in the frame.Check the spring shackles also.
deuce lover is offline   Reply With Quote
Old 08-22-2022, 03:28 PM   #3
ford38v8
ford38v8's Avatar
Unusual that it's the passenger side, had to look whether you had a RHD. Could be a PO reversed a sagging spring, maybe a shock absorber, being a truck, maybe an overload bent the frame, or broke a leaf.
Alan
Old 08-22-2022, 03:35 PM   #4
38bill
38bill's Avatar
Could also be the bumper brackets themselves. Loosen them up and see if you can raise the low end and lower the high.
38bill is offline   Reply With Quote
Old 08-22-2022, 03:45 PM   #5
woodiewagon46
If you are using a stock spring the "U" bolt's that clamp the spring into the crossmember might be tighter on one side clamping the spring unevenly.
woodiewagon46 is offline   Reply With Quote
Old 08-22-2022, 03:56 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Before messing with bumper brackets take measurements from wheel opening to the ground to determine if in fact the body is leaning or not.
Old 08-22-2022, 03:56 PM   #7
mike in tucson
Troubleshooting 101? With the wheels pointed straight ahead:
1. are the front tires the same size on both sides?
2. are the rear tires the same size? One rear tire larger makes the truck sit wrong
3. Measure from a spot on the bumper to the ground. Repeat for the other side.
4. Is the bumper bent in the up/down direction? Check for straightness.
5. Measure from a point on the frame to the ground. Do same on other side.
6. Measure from point on axle to ground and do the same on the other side
7. measure from fender sheet metal over tire to ground on both sides.
Using this data allows you to isolate where tilt is located.
mike in tucson is offline   Reply With Quote
Old 08-22-2022, 04:00 PM   #8
petehoovie
petehoovie's Avatar
Originally Posted by randy993 View Post
Hello all,
Old 08-22-2022, 04:08 PM   #9
Jack E/NJ
Jack E/NJ's Avatar
Tree trunk and parking lot look tilted in that direction too. Could be gravitational. 8^)
Jack E/NJ is offline   Reply With Quote
Old 08-22-2022, 04:36 PM   #10
Bored&Stroked
Bored&Stroked's Avatar
Usually, it is my FAT rear-end that causes the problem . . . LOL!
Old 08-22-2022, 04:37 PM   #11
randy993
randy993's Avatar
Yeah that parking lot picture is not the best although the lot is level..my truck has been like this since I have owned it. The tires are all the same size. I measured from the bottom of the shocks down and also the frame at the radiator. Both points measured 1” different. I park it on ramps (I have a mid rise lift). I’ll have to start going down each side and see if it is the whole length of the truck. When you look at the rear it doesn’t look that bad..
Old 08-22-2022, 04:55 PM   #12
Roger W Gerow
Many years ago I was the proud owner of a 1936 Ford 3 window coupe. (wish I still had it!) The left front fender stared to go much lower than it should be. Upon examining the front cross member and frame I discovered the cross member had a large crack just inboard of the frame, but hadn't broke completely yet. My solution to this situation was to put a 6 inch spring shackle on the right side of the rear spring. Was fairly level after that. When I sold the car sometime later it still drove just fine!
DD658
Roger W Gerow is offline   Reply With Quote
Old 08-22-2022, 04:57 PM   #13
Karl Wescott
Karl Wescott's Avatar
Bodywork on right side done with lead... on the left side with bondo??? LOL.
Seriously, good ideas on posts above.
You might try putting it on 3 jack stands, 2 at the rear of the frame (leveled) and one at the center of the front crossmember. If the truck levels out you have suspension/spring/shock issues, if it remains caddywampus then it looks to be frame of body issues.
Karl Wescott is offline   Reply With Quote
Old 08-22-2022, 05:21 PM   #14
34pickup
34pickup's Avatar
Tell your wife to lose weight.....☺
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 08-22-2022, 05:58 PM   #15
cmbrucew
cmbrucew's Avatar
Spring center bolt broken,
Bruce
Sorry I forgot it was a pickup
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 08-22-2022, 06:09 PM   #16
jimvette59
jimvette59's Avatar
The bumper is not level.
jimvette59 is offline   Reply With Quote
Old 08-22-2022, 06:55 PM   #17
petehoovie
petehoovie's Avatar
Looking at the picture, it appears as though you have a front-end wheel alignment problem as well...
Old 08-22-2022, 10:56 PM   #18
ford38v8
ford38v8's Avatar
Nah, it just looks that way because his spare tire is out of balance. 🤪
Alan
Old 08-22-2022, 07:51 PM   #19
Lawson Cox
Lawson Cox's Avatar
Hello all,
Fat girlfriend??? (The devil made me ask that question.)
Old 08-22-2022, 09:46 PM   #20
fordor41
fordor41's Avatar
when I look at the pic, it appears that the distance from the bottom of the headlights to the bumper appear to be equal. more of the suspension shows on drivers side than pass. side. my guess is either F or R spring related.
fordor41 is offline   Reply With Quote
