Old 07-17-2022, 10:11 PM   #1
Raaf
Default Engine Stand Adapter
Hi,
I am looking at engine stand adapters - pretty common design like this one:
https://www.macsautoparts.com/model-...8-23763-1.html
The question I have is, shouldn't there be a hole drilled through the tube at the back to accommodate the rotating bar found on most stands? How is the tube actually retained in the stand?
Is it expected that we should just drill this?
I would expect it to be drilled like this (completely unrelated model for different type of 4 cylinder):
https://www.parkautomotorsports.ca/p...-stand-adapter
You can see that this example is drilled to accept the rotating rod and pin to hold it in place.
Thanks for any advice you have.
Raaf
Raaf is offline   Reply With Quote
Old 07-17-2022, 10:25 PM   #2
Bbhf
Bbhf's Avatar
Default Re: Engine Stand Adapter
Raaf: i have one of these and use it often: other supply houses have it for a lot cheaper: hope this helps: you can drill the hole to whatever size you need: sk
Bbhf is offline   Reply With Quote
Old 07-17-2022, 10:35 PM   #3
Pete
Originally Posted by Raaf View Post
Hi,
Raaf
Those prices are extortion. Besides the welding looks like it was done by a
spastic.
You can make one for $10 worth of material and $1 worth of electricity.
Old 07-17-2022, 11:02 PM   #4
Bbhf
Bbhf's Avatar
i will agree if you are a fabricator/welder or have someone who can make it for you: if you sourced it out to a good fabricator it would be a hefty tag: mine came in with a bunch of parts i picked up: sk
Old 07-17-2022, 11:19 PM   #5
Bbhf
Bbhf's Avatar
Hope these pics post: Here is one i found in an old timers shop: simple: sk
Old 07-18-2022, 06:27 AM   #6
nkaminar
nkaminar's Avatar
You will need the holes to keep the engine from rotating. The engine will want to rotate.
The threaded bolt holes for the water inlet are strong enough to support the weight of the engine. You can just use the adapters that came with the engine stand and use the right length bolts. If you have problems with the adapters moving you can tack weld them to the stand. In my case I used a lot of weld because I have no plans to use the stand with any other engine.
nkaminar is online now   Reply With Quote
Old 07-18-2022, 10:50 AM   #7
katy
katy's Avatar
I put this 60-1 worm drive reduction gear on my engine stand, it holds the engine in whatever position it's put.
katy is online now   Reply With Quote
Old 07-18-2022, 12:45 PM   #8
Raaf
Thanks all - really helpful.
At the very least it solves the mystery as to whether or not the adapter is going need to some holes drilled. Definitely does - and that makes sense.
...and indeed, the cost of the adapter is a ridiculous. You can find them for 1/2 the price of the one I linked to above, or as has been pointed out - you can fabricate your own.
Old 07-18-2022, 12:45 PM   #9
Raaf
@Katy - fancy!
Old 07-18-2022, 02:15 PM   #10
old ugly
old ugly's Avatar
this was free and about an hour to make.
send me your $150 plus shipping and i will send you a pc of 1 1/2" angle iron. lol
https://www.fordbarn.com/forum/showthread.php?t=310021
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 07-18-2022, 03:02 PM   #11
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Talking Re: Engine Stand Adapter
spastic.
Hey Pete: don’t hold back!
Old 07-18-2022, 03:13 PM   #12
Pete
LOL....When I see some of the welding being offered these days, it makes me want to barf.
We had to learn to lay a row of dimes on a snoose can in high school.
Old 07-18-2022, 04:18 PM   #13
old ugly
old ugly's Avatar
no welding on the one i showed you
old ugly
Old 07-18-2022, 10:13 PM   #14
Huckster
Huckster's Avatar
Find one of these.
File Type: jpg 7F0AD765-4890-43AB-B55E-CB80F60F4523.jpg (56.1 KB, 42 views)
Dont get too excited.
Huckster is offline   Reply With Quote
