Old 02-14-2022, 06:11 PM   #1
old ugly
old ugly's Avatar
Default easy engine stand bracket
there are lots of ideas out there and this has most likely been done before. its cheep and easy.
-1 1/2' angle iron drilled to match the oil pan bolts (left side) and two holes drilled for the arms..
the picture shows it on the bottom of the pan flange but it accually goes on the top of the flange so the pan can be bolted on.
i don't synch the pan flange bolts to tight because the flange is angled and i don't want to chance cracking them.
the other two arms simply bolt to the water inlet bolt holes.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
