Old 07-15-2022, 12:45 PM   #1
38convsedan
38convsedan's Avatar
Default Antenna connection
Install of windshield antenna has come to a halt…
The antenna lead won’t fit in the female end of antenna cable.
Is there a transition connector for this?
File Type: jpg F22E2E61-E8FD-401A-8A7C-56BB236AA178.jpg (23.8 KB, 53 views)
38convsedan is offline   Reply With Quote
Old 07-15-2022, 01:04 PM   #2
chriscris
chriscris's Avatar
Default Re: Antenna connection
I havent hit that point yet, but in researching correct parts, it appears the aftermarket leads dont make much sense like that.
Still figuring it out as well.....
chriscris is offline   Reply With Quote
Old 07-16-2022, 11:45 PM   #3
38convsedan
Problem solved!
The problem was with the female cable end.
I took a small uni-bit and by hand very slowly turned the bit to slightly enlarge the opening.
The antenna lead then snuggly plugged in!
Old 07-17-2022, 12:08 AM   #4
Fourdy
Fourdy's Avatar
I have this from a 40 if it would help.
Fourdy is offline   Reply With Quote
