Old 07-13-2022, 12:08 PM   #1
jack99
Default Radiator hoses for 1935 ford
Can anyone recommend a source for radiator hoses for a 1935 Ford. I have tried many of the usual sources an all seem to be out of stock. Any help would be appreciated.
Thanks in advance.
jack99 is offline   Reply With Quote
Old 07-13-2022, 01:27 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Radiator hoses for 1935 ford
Do you have a stock engine? Someone is making a hose for the 35-36 with a later engine with the hose connection in the center of the head.
Old 07-13-2022, 01:49 PM   #3
Kube
Kube's Avatar
Thanks in advance.
Jack, Napa sells straight radiator hose by the foot. Just figure out the inside diameter(s) and total length you require.
Old 07-13-2022, 05:53 PM   #4
Jacques1960
Jacques1960's Avatar
I purchased a set of red line hoses for my ‘36 Phaeton from Joes - good fit, although lower hoses elicited the usual profanity trying to bend the unbendable into a too small space. Note that upper hoses went in without modification while both lower hoses required trimming prior to application of profanity.
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 07-13-2022, 06:59 PM   #5
ford38v8
ford38v8's Avatar
Jacques, Next time that job comes up, simply disconnect the front motor mounts and lift the engine sufficiently to angle a hose onto the inlet/outlet. Then as you lower the engine, that hose knows where it's going. Do one hose at a time, orient the clamps to convenient positions, and while you're at it, replace your mushy old motor mounts.
Alan
Old 07-13-2022, 07:43 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Nahh! That's way TOO easy! Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 07-13-2022, 07:46 PM   #7
OLDMANKOHOUT
These are the only sets we have in at the moment
#05729
RADIATOR HOSE SET- FORD SCRIPT - RED STRIPE
1932-36 4 HOSES - 8 CLAMPS FOR STOCK FLATHEAD ENGINE LIMITED STOCK
https://www.vintageford.com/part_sea...5729&Category=
OLDMANKOHOUT is offline   Reply With Quote
Old 07-13-2022, 11:53 PM   #8
cas3
I like to use " sil glyde" on hose installations, slides on easy and comes off without a fight years later. Napa brand name, I suppose there are others similar
Old 07-13-2022, 11:58 PM   #9
ford38v8
ford38v8's Avatar
From that name, it sounds like silicone, and there isn’t anything better for rubber.
Alan
