Old 07-03-2022, 02:58 PM   #1
John K. Endrizzi
Default Inlet restrictor diameter. for EAB oil filter
I have a stock oil filter canister. It is missing the inlet tee. What diameter should the restrictor be ? A friend told me .125. I found a broken brass tee with an electrical pressure/warning unit attached in a junk parts box I was given. The running leg of the tee diameter is .140. What is the correct diameter ?
John K. Endrizzi is offline   Reply With Quote
Old 07-03-2022, 03:11 PM   #2
marko39
Default Re: Inlet restrictor diameter. for EAB oil filter
Diameter should be about .060. You can solder a fitting and drill the correct size hole. I think Napa still lists the fitting.
marko39 is offline   Reply With Quote
Old 07-03-2022, 03:42 PM   #3
Ziggster
I was looking for the same info. I think J actually had written the NAPA P/N down somewhere last year.
Ziggster is offline   Reply With Quote
Old 07-03-2022, 04:02 PM   #4
John K. Endrizzi
Ziggster, if you find the Napa p/n , please post it.
Old 07-03-2022, 04:45 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
This is one way to do it
Old 07-03-2022, 05:04 PM   #6
John K. Endrizzi
Thanks MERC-CT !
Old 07-04-2022, 07:21 AM   #7
marko39
Napa # wh1512
Old 07-04-2022, 08:29 AM   #8
34PKUP
34PKUP's Avatar
Napa # wh1512
Yep, that's what it shows in post #5 above.
34PKUP is offline   Reply With Quote
Old 07-04-2022, 08:33 AM   #9
Ziggster
Correct. I found my hand sketch of the external oil plumbing and that is the P/N I hand jotted down as well.
File Type: jpg F84D168C-1F79-4584-B429-40EE0C2C152B.jpg (45.2 KB, 31 views)
Old 07-04-2022, 04:35 PM   #10
Ziggster
I now remember going to the local NAPA store last year looking for the fitting. They didn’t have it and told me that the NAPA stores in Canada are different from those in the USA, and their “systems” are separate and do not communicate. Told me they deal with Fairview fittings, and if I could find it in their catalogue, then they could order it for me. Couldn’t find in in the Fairview catalogue. Started looking again, it it seems the Weatherhead/NAPA WH1512 is getting harder to source. Seems Danfoss has now acquired Weatherhead. Found a guy on eBay and an American site, but shipping was approaching US$25 plus. So, found this company in Canada. Ordered one (CAN$25.24!), but still waiting on shipping quote which is kinda weird.
https://www.motionindustries.com/
Old 07-04-2022, 06:04 PM   #11
John K. Endrizzi
Thanks to all for your help . I have modified my own fitting. I solder one leg tog a brass tee shut. Next I chucked it up in my lathe and drill that leg with a .062 bit.
