Old 06-03-2022, 09:54 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Model "B" Oil Pressure
If I put an oil pressure gauge on a Model "B" engine, how much pressure would I see on the gauge while cruising at 50 MPH?
Bob Bidonde
Old 06-03-2022, 11:56 AM   #2
Jim Brierley
Default Re: Model "B" Oil Pressure
With hot oil, probably less than 1 lb. With cold oil, maybe 3 lbs.
Jim Brierley is offline   Reply With Quote
Old 06-03-2022, 11:55 PM   #3
CWPASADENA
CWPASADENA's Avatar
My "B" engine will run 6 lbs. hot at 2000RPM. About 1 lb. at idle. Babbit bearings, about 18K miles on engine.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 06-04-2022, 03:23 AM   #4
Benson
My Model B engine with Babbitt and 20 K (ON REBUILD) runs 2 to 3 lbs hot at Idle (450 RPM) and 8 to 9 at 60 MPH.
Benson is offline   Reply With Quote
Old 06-04-2022, 08:33 AM   #5
Bob Bidonde
Thanks all for your replies. I thought that the Model "B" would develop higher oil pressure than you all report. I likely will not bother to install an oil pressure gauge.
Bob Bidonde
Old 06-04-2022, 08:44 AM   #6
johnneilson
Bob
The B motor in stock form is not a pressurized system. It is an attempt at directing the oil to the bearings. With a couple small modifications the system can be pressurized. Of course pump and drive will need attention too. I run approximately 30-35 psi on street motors and 60-70 on the race motors.
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 06-04-2022, 08:45 AM   #7
johnneilson
Bob
John
Old 06-04-2022, 07:27 PM   #8
Synchro909
Synchro909's Avatar
My B motor is equipped with a warning light, not a gauge. The light comes on at 9 psi and the only time I see it is when doing a Right hand turn - that's when the pump is drawing in air, not oil. Actual pressure at 50 mph - I don't know but it's enough.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
