Old 04-11-2022, 07:15 AM   #1
CatMan1
Default Loose Front Wheel Bearings
The driver's side on my '26 is fine. No wiggle or looseness at all. The passenger side is another story. I took it apart yesterday as I could pull the whole assembly out and push it back on the spindle about 1/8". The spindle nut was as tight as you could possibly get it. The outer bearing came apart when I took it out. How could the assembly be so loose yet the nut so tightened up?
CatMan1 is offline   Reply With Quote
