Old 03-10-2022, 12:26 PM   #1
The "A" Team
Default Looking for the rubber bushings that go on the front engine mount
Hi everyone,
I'm in the midst of restoring my 1930 Model A Coupe and have been looking high and low for the rubber bushings that go on the stem of front engine mount yoke (please see the pics in the attached PDF). I've tried multiple places, Mac's, CWMoss, A-Fordable, Tam's, Ebay, but no one seems to have them.
Does anyone know where I can find them?
Thanks in advance.
John
The "A" Team is offline   Reply With Quote
Old 03-10-2022, 12:29 PM   #2
Stingray70
Stingray70's Avatar
Default Re: Looking for the rubber bushings that go on the front engine mount
I don't believe there is supposed to be rubber there. Mine has a leather washer and a brass bushing which rests in the crossmember hole. Someone will correct me shortly if I am wrong
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 03-10-2022, 12:33 PM   #3
Stingray70
Stingray70's Avatar
Also IIRC there have been some posts here about aftermarket mods to the front mount which allegedly reduced vibration. The consensus was that thos do more harm than good and it's best to stick with the stock setup. The vendors sell all the correct parts you need.
1930 Standard Coupe
Old 03-10-2022, 12:41 PM   #4
The "A" Team
I don't know, maybe the original owner put them on there? Those bushings pretty old, stiff, cracked, and fall apart with just a little pressure. There is a metal washer under the lower bushing where the castle nut goes on, it's just hard to see because it's pretty much sunk into the bushing.
If there's a different setup for that mount, I would definitely like to know, so I get the right parts.
Old 03-10-2022, 12:42 PM   #5
Bob C
Yes, throw that stuff away and get the original style.
https://modelastore.com/index.php?ro...&category_id=0
Old 03-10-2022, 01:21 PM   #6
The "A" Team
Oh, that was the original style? I thought that one piece spring setup was the original, since it was so simple.
Old 03-10-2022, 01:37 PM   #7
Stingray70
Stingray70's Avatar
In addition to the kit above, you will need the brass bushing. It is sold separately
1930 Standard Coupe
Old 03-10-2022, 02:24 PM   #8
Bob C
The brass bushing was deleted in February 1929.
Old 03-10-2022, 02:31 PM   #9
The "A" Team
I found a kit with the bushing. Thanks for your help, I really appreciate it.
Old 03-10-2022, 03:13 PM   #10
Ruth
I didn't know that. What holds the yoke in the center of the crossmember? I have it on my 1930.
Ruth
Old 03-10-2022, 04:07 PM   #11
rotorwrench
rotorwrench's Avatar
Some also use the Float a Motor front and rear mount mod. My old 29 came to me with an aftermarket set up that looks like two bicycle seat springs joined together with two rubber cushions shaped to fit I side the springs. The cushions almost look like rubber bottle stoppers. I had not ever seen this set up before I replaced it with the OEM type setup.
Old 03-10-2022, 04:07 PM   #12
31Tudor
31Tudor's Avatar
It was just a washer. As Bob mentioned, the top side was a leather washer, then the underside was a flat washer, spring and nut. I think it was redesigned to float a little more.
31Tudor is offline   Reply With Quote
Old 03-10-2022, 05:00 PM   #13
Synchro909
Synchro909's Avatar
Deleted
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 03-10-2022, 05:34 PM   #14
mdsbob
That is an after-market mount sold by Western Auto, OTASCO, etc.
mdsbob is offline   Reply With Quote
Old 03-10-2022, 06:00 PM   #15
OLDMANKOHOUT
We offered those motor mount kits way back in the 70's-80's. Believe they were by Gene Scott at Antique Auto Parts in Rosemead at the time.
OLDMANKOHOUT is offline   Reply With Quote
Old 03-10-2022, 06:55 PM   #16
SonicRaT
Does anyone have any advice on getting the replacement parts installed with the engine still in? I have one of those same designs on my engine, missing all of the rubber, that vibrates pretty bad. I have all of the new "original" style parts but I can't get the old yoke and springs out due to being unable to lift the engine high enough to clear...
SonicRaT is offline   Reply With Quote
Old 03-10-2022, 07:32 PM   #17
The "A" Team
That's exactly what mine looks like, and it also has rubber bushings on the top and bottom of the yoke stem. Those were the parts I was looking for.
Old 03-10-2022, 07:46 PM   #18
SonicRaT
I just went to replace my springs and such yesterday as I noticed it looked "flat" and didn't have a spring underneath the crossmember and I have bad vibrations -- then I discovered my setup was completely different from what I ordered and looks exactly like what you have pictured and I couldn't get the thing out from behind the crank pulley because the springs wouldn't come out separately. Crazy that this was at the top page of the barn right as I was about to start looking into what that setup was and why it was different. Mine doesn't have any rubber under the bottom of it and is sitting directly on the center wire of the spring and is cinched tightly on the bottom with washers... Guess that's a bit of a deviation from how it was originally supposed to be and explains some of my vibration.
Old 03-10-2022, 08:05 PM   #19
Model A Canuck
Model A Canuck's Avatar
Try Bert's
www.modelastore.com
Model A Canuck is offline   Reply With Quote
Old 03-10-2022, 08:11 PM   #20
Synchro909
Synchro909's Avatar
I have all of the bits I will need to do this job out on the workbench as I type. I guess we make it double crazy.
From experience, I have the same concern as SonicRat about getting the old one out with the engine in the car. I considered taking the pulley off but I don't think that is possible either. Maybe I can get in there enough to cut up the old one first.
