Old 02-24-2022, 11:35 AM   #1
31slant
Default Wheels and tires?
What if and after market modern 15" or 16" wheels that will fit in the fender wells?
I looking for something like the look of Cragars. And white walls. Any Sugestions?
31slant is offline   Reply With Quote
Old 02-24-2022, 12:19 PM   #2
Jim Brierley
Default Re: Wheels and tires?
I'm running 205-15's on the front and 215-15's on the rear. I have trouble posting pic here but if you want to e-mail me at [email protected],
i can send you one.
Jim Brierley is offline   Reply With Quote
Old 02-24-2022, 12:54 PM   #3
Charlie Stephens
You might also post your question on HAMB where you might find more knowledgeable audience for your question.
https://www.jalopyjournal.com/forum/...ssage-board.5/
Charlie Stephens
Old 02-24-2022, 02:21 PM   #4
Gary WA
Gary WA's Avatar
Early Ford Wire Wheel Tech - Hot Rod Forum : Hotrodders Bulletin Board
www.whidbeymodelaclub.com
Old 02-24-2022, 09:35 PM   #5
Russ B
Coker has tires in multiple sizes and side walls
I run 15" bias plys white walls 5.90x15 front and 8.20x15 rear. they fit the wells on by 29 nicely. I also use '49 Mercury centers because i prefer the plain hub caps
yes it is not completely original, but combined with hydraulic brakes, the car stops much better.
Pretty soon it will be running with a new Burtz block, and better stopping power may be even more important than 21" tires can provide.
Russ B is offline   Reply With Quote
Old 02-25-2022, 09:36 AM   #6
31slant
I thank you all for your input. but i think i needed to correct myself. I would like to put the spare on/in the front fender well. have a four door and looking to run a trunk on the back.
Old 02-25-2022, 09:42 AM   #7
1931 flamingo
1931 flamingo's Avatar
Now that you've clarified what you want to do, I don't think you're going to find anything to fit your needs.
Even stock 19" wheels with Firestone's usually have to be put in the wells UN-inflated.
Paul in CT
