Old 02-17-2022, 07:09 PM   #1
34 fordor owner
34 fordor owner's Avatar
Default 34 Distributor Vacuum Brake
Could someone explain what the vacuum brake does on a 1934 Ford dome-style distributor? Could it cause starting issues if not set right?
34 fordor owner is offline   Reply With Quote
Old 02-17-2022, 07:23 PM   #2
DavidG
DavidG's Avatar
Default Re: 34 Distributor Vacuum Brake
It retards the centrifugal advance weights to limit the amount of spark advance. At the low speed of startup, it is unlikely that the centrifugal advance weights are extended to any extent. Therefore, it is highly unlikely that it is a root cause of any starting issue.
Old 02-17-2022, 07:25 PM   #3
34 fordor owner
Thank you very much!
Old 02-17-2022, 10:21 PM   #4
DavidG
DavidG's Avatar
You're welcome!
