Old 02-14-2022, 06:30 PM   #1
Pg409
Default Sending unit removal 36 coupe
Climbing in my rumble and closing the lid to access the sending unit in my coupe Is a lot of fun! Not.
Can the sender be removed in the car?
Pg409 is offline   Reply With Quote
Old 02-14-2022, 07:14 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Sending unit removal 36 coupe
The rumble seat can easily be removed. Lift the front edge and pull forward to clear the seat back, then lift out.
Alan
Old 02-14-2022, 07:14 PM   #3
wamnram
wamnram's Avatar
Yes, as you open the lid, when the lid is almost vertical, there will be a gap between the lid and the rear of the body. You can access the sending unit by sliding a not too fat arm and hand down in the gap. Not easy but I have done it several times. Bring your patience!
Wayne
wamnram is offline   Reply With Quote
Old 02-14-2022, 07:21 PM   #4
ford38v8
ford38v8's Avatar
That works, but you need to hold the lid steady with one hand if you really want to keep the other.
Alan
Old 02-14-2022, 07:57 PM   #5
Pg409
The point I was really trying to make was can the sending unit be removed and replaced through the access hole?
Old 02-14-2022, 08:05 PM   #6
wamnram
wamnram's Avatar
Yes!
Wayne
Old 02-14-2022, 08:07 PM   #7
Pg409
Thank you!
Old 02-14-2022, 10:20 PM   #8
koates
If your fuel gauge is playing up then you should do some testing to make sure the gauge and wiring is OK before going to the trouble of removing the tank sender. Just guessing is not the way to go. Regards, Kevin.
koates is offline   Reply With Quote
