Old 02-13-2022, 12:28 PM   #1
ssffnomad
ssffnomad's Avatar
Default 39’ Coil Location ?
Hello. 39’ Deluxe with original motor . Offenhauser intake with 2 carbs. Generator being replaced with Power Gen Alternator. Where have you guys mounted the Coil ?
T/Y. Stretch.
ssffnomad is offline   Reply With Quote
Old 02-13-2022, 12:35 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 39’ Coil Location ?
It really depends on what distributor you are using. What is wrong with the stock location with a Skip Haney coil?
Old 02-13-2022, 12:36 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
T/Y. Stretch.
On top of the stock distributor
John
Old 02-13-2022, 12:54 PM   #4
ssffnomad
ssffnomad's Avatar
Ok, don’t hate me too bad.
Also replacing the original 6V Distributor with a Mallory Unilite Electronic 12V.
Old 02-13-2022, 01:10 PM   #5
flatjack9
flatjack9's Avatar
I mounted mine on the inner fender.
Old 02-13-2022, 01:26 PM   #6
JM 35 Sedan
If you're using a standard cylindrical coil you could use an 8ba type coil bracket.
John
Old 02-13-2022, 01:32 PM   #7
Jack E/NJ
Jack E/NJ's Avatar
You can mount it anywhere with a store-bought ready-made kit for ~$60. Or one fashioned from a nice piece of pine scrap.
Jack E/NJ is offline   Reply With Quote
Old 02-13-2022, 09:21 PM   #8
ssffnomad
ssffnomad's Avatar
So D. Carpenter has a coil mount for 48’-53’ truck & 49’-53’ car.
#8BA-12043
Unfortunately my Puter at the moment , is not letting me post a picture of mount.
Looks like it attaches to pass side front head bolts.
Will this also bolt up to our 39’ head bolts ?
T/Y much.
Stretch
Old 02-13-2022, 11:17 PM   #9
flatjack9
flatjack9's Avatar
The 8BA and 8RT have dedicated bolt holes for the coil bracket which the early heads do not have.
