Old 01-22-2022, 07:02 PM   #1
Wayne B
Default 1950 Ford F3 Fuel Issues
Good evening, I have a fuel issue on my flathead ford. Motor was rebuilt and know I can’t keep the truck running. Truck will idle with no problem but make it around the block. It’s like a vapor lock or something. Does anyone have any suggestions. Before motor was rebuilt I wasn’t having issues.
Wayne B is offline   Reply With Quote
Old 01-22-2022, 07:17 PM   #2
ford38v8
ford38v8's Avatar
Default Re: 1950 Ford F3 Fuel Issues
Before your motor was rebuilt, your flex line fittings were tightened correctly.
Alan
ford38v8 is online now   Reply With Quote
Old 01-22-2022, 07:22 PM   #3
Wayne B
Yes all connections were tightened. Just can’t figure this issue out.
Old 01-22-2022, 07:39 PM   #4
drolston
drolston's Avatar
When driving, does it run rough from the beginning and then die, or does it run normally for a way, and then stumble and die.
Old 01-22-2022, 07:49 PM   #5
Ggmac
Blocked fuel line , blocked exhaust, wrong gas cap ( not vented ) bad coil or condenser, carb dumping fuel ( would have black exhaust)
Ggmac is offline   Reply With Quote
Old 01-22-2022, 07:55 PM   #6
Wayne B
Motor running with no issues. Then it just shuts down no warning no noise
Old 01-22-2022, 08:03 PM   #7
tubman
tubman's Avatar
Can you start it back up right after it dies, or do you have to wait a while?
Old 01-22-2022, 08:05 PM   #8
FortyNiner
FortyNiner's Avatar
I would start with the fuel line. Check everything and assume nothing.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 01-23-2022, 12:06 AM   #9
ford38v8
ford38v8's Avatar
Either your pump is sucking air, or your flex line has collapsed. Is the flex an old one, or a new fuel resistant line? Have you checked pump delivery volume?
Alan
Old 01-23-2022, 12:45 AM   #10
V8COOPMAN
V8COOPMAN's Avatar
"tubman" asks a very relevant question above in post #7 with regard to the symptoms you're experiencing! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-23-2022, 02:26 PM   #11
Wayne B
I have a hard time re starting. After it sits I can crack it.
Old 01-23-2022, 03:21 PM   #12
Bob C
To me that seem more like ignition problem. Seems like if it was fuel related
you would get some hesitation or surging before it quit.
Old 01-23-2022, 05:26 PM   #13
tubman
tubman's Avatar
Sounds heat related, probably a coil or condenser.
There's an old saying : "90% of all carburation problems are ignition related, while most ignition problems are caused by a faulty fuel delivery system".
Old 01-23-2022, 06:18 PM   #14
drolston
drolston's Avatar
To determine if it is fuel starvation, - after it dies, look down into the carb and full stroke the throttle to see if you get a stream of fuel into the venturi from the accelerator pump. If not, start working your way back through the fuel pump, fuel filter, flexible fuel hose, gas cap vent, etc.
If you get a good squirt from the accelerator pump, it is probably an ignition problem. After it dies, crank it right away to see if a spark plug wire will jump a half inch gap with a bluish white spark.
Old 01-24-2022, 09:07 AM   #15
big job
big job's Avatar
As you are driving it starts staving did you pull the choke and it did try?
Happened to me. My truck mint 1956 F350 express I worked the night shift till retirement not good to start walking at midnight a mile to my police station. ya late but I am the 3rd shift super. no phones then call next
tow in line good..enough history. next day pore cup gas starts fine-dies:
I know this is stupid thoughts. Back to you; I took the fuel sender out Ok.
shine down there with light guess what; slivers of green like plastic right sucked into the fuel feed...bottom line someone before me sucked gas
with a green garden hose and sliced hose on the filler pipe.
So I say blow fuel line back drain tank and stick shop vac in problem solved......
big job is offline   Reply With Quote
