Old 12-14-2021, 01:03 AM   #1
Lawrie
Lawrie's Avatar
Default MSD distributor
Does any one know where I can still get an MSD distributor for a customers flathead MSD 8351 or a quality unit that will replace the electronic unit fitted that failed.(not an MSD unit)
Thanks Lawrie
Lawrie is offline   Reply With Quote
Old 12-14-2021, 03:08 AM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: MSD distributor
I see Outlaw Speed in Australia stock some MSD distributor stuff. You may be lucky here.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 12-14-2021, 09:07 AM   #3
Gene1949
Gene1949's Avatar
https://help.summitracing.com/app/an...s-to-australia
They list an 8BA MSD all in one ready to run distributor.
Not too sure about their proprietary electronics internal but their pickup coil and reluctor is old Chrysler.
I pulled their electronics and used a GM HEI brain and later model E-coil mounted externally. The really smart thing to do would be to lock out the advance(s) [vacuum and mechanical] and use MSD's programmable control unit with a MAP sensor.
Having said that, I travel a lot in that old Ford and needed to be able to fix it at NAPA or at a wreaking yard.
Old school paranoia I guess
Gene1949 is offline   Reply With Quote
