Old 12-13-2021, 08:43 PM   #1
Cleveland39
Cleveland39's Avatar
Default Hand throttle carb connection - '39
Who wants to try to explain to me how this throttle connection to my 94 carb on my '39 Standard is supposed to work? This is on the left side of the carb and there is no moving linkage, just the ball on the end of the shaft.
Cleveland39 is offline   Reply With Quote
Old 12-13-2021, 09:03 PM   #2
Kube
Kube's Avatar
Default Re: Hand throttle carb connection - '39
It appears as if you are missing a piece or more. I have attached two photos for you to compare what you have and what you should have.
Old 12-13-2021, 09:06 PM   #3
deuce_roadster
deuce_roadster's Avatar
Ha ha, Henry Ford Cruise control!! NOT.
Old 12-14-2021, 12:06 PM   #4
rockfla
rockfla's Avatar
Not sure IF this helps any over what KUBE has already posted but here is the set-up on my 39 Mercury, KUBE, again, can speak to the same or different than the 39 standard Ford BUT here is how it's set up on my Mercury!! SORRY for the "spy phone" 90 degree turn??
File Type: jpg 0C95CE2B-5650-4AC1-B994-F8F18218BBF5.jpg (75.4 KB, 27 views)
File Type: jpg E4A8F6C8-E412-4A38-94AE-47986093F31C.jpg (75.3 KB, 26 views)
File Type: jpg B34EB1C4-06DB-4A6D-9877-090F50C63DCD.jpg (82.0 KB, 24 views)
