Old 12-01-2021, 08:40 AM   #1
Leadfoot4U
Leadfoot4U's Avatar
Default Emergency brake pivot bolt
I'm replacing my '22 rear brake shoes using the one piece lined type. My question is should the pivot bolt be run down tight before adding the rear castle nut? Or, just snug enough to allow the brake to actually pivot? The Service Manual simply states "Insert brake shoe bolt through brake shoe, running bolt down into housing flange; run down nut tightly on end of bolt,...."
Leadfoot4U is offline   Reply With Quote
Old 12-01-2021, 02:33 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Emergency brake pivot bolt
I would be tempted to follow the book. But then the shoes you are using are aftermarket so it might be asking questions from the maker of the shoes.
Old 12-01-2021, 07:32 PM   #3
stevests
stevests's Avatar
Just tight enough to prevent "flopping" & still pivot.
stevests is offline   Reply With Quote
Old 12-02-2021, 10:18 AM   #4
Leadfoot4U
Leadfoot4U's Avatar
What the.....!!
I'm responding to Michaelunump because I can't send a PM to the administrator unless I have 10 posts in this forum....this make 10.
