Old 11-12-2021, 04:25 PM   #1
Clem Clement
Clem Clement's Avatar
Default Gorden Smith compressor air pressors
Air compressor pressure and engine compression olease.
Clem Clement is offline   Reply With Quote
Old 11-12-2021, 10:21 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Gorden Smith compressor air pressors
I would have to look at the head I have off, if I remember correctly the combustion chamber looks "B"
For sandblasting it run about 45 psi, I regulate the pressure with governor speed to match diameter of nozzle
When it was running a jackhammer I would crank up the governor never measured rpm, suspect around 1800-2200, pressure regulator would kick unloaders about 125
Old 11-13-2021, 01:51 PM   #3
Clem Clement
THANK YOU
The GWC Club's runs fine but stalls under load. They think it needs rings??
