Old 09-01-2021, 10:39 PM   #1
olddaze32
olddaze32's Avatar
Default Trying to identify 59A style aluminum heads
I have a pair of early 24 stud aluminum heads. They both have the number
81 6050 49 on them. There is a small circle with a C in the middle on the top right and the number 140 on the top left. Any ideas what these were on?
olddaze32 is offline   Reply With Quote
Old 09-01-2021, 11:26 PM   #2
Brian
Brian's Avatar
Default Re: Trying to identify 59A style aluminum heads
81 denotes 1938...these fit the first of the 24 stud blocks. In order to fit them to the post war blocks [with the relocated valve positions] you'll need to clearance the eyebrows in the heads.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 09-01-2021, 11:33 PM   #3
mercman from oz
mercman from oz's Avatar
1938 Ford V8 24 Stud Heads.
Old 09-01-2021, 11:38 PM   #4
Brian
Brian's Avatar
The other difference is the temp gauge fitting...originally these had the capillary style gauge, the heads are tapped 5/8 NF to suit. The later [59A] style heads used electric temp gauge; they are tapped 3/8 pipe thread for the senders.
