Old 08-29-2021, 05:19 PM   #1
russcc
Default 1935 NORS brake drums
I have several 48, (1935) replacement brake drums, Couple questions;
Are they one year only, 1935 ?
Are the front & rear drums different or the same ?
Is the difference between the 48, and O1A drums, the 48 fit inside the backing plate, and on the O1A's, the backing plate fits in the drum slot ?
Are those drums still available, as I can't find them listed in Joe's catalog ?
Thank you.
russcc is offline   Reply With Quote
Old 08-29-2021, 06:45 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1935 NORS brake drums
Do they look like these? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-29-2021, 09:11 PM   #3
rich b
rich b's Avatar
From my experience '35 front and rear drums are totally different from each other and from any other Ford drum.
The rear hub, if removed from the drum may look like '40-'41; but is different.
rich b is offline   Reply With Quote
Old 08-30-2021, 07:33 AM   #4
1931 flamingo
1931 flamingo's Avatar
I thought it was 36 that was different??
Paul in CT
Old 08-30-2021, 09:09 AM   #5
DavidG
DavidG's Avatar
'35, '36, and '37-'38 drums are all unique with the latter two having the wide bolt pattern and of course the fronts and rears are unique for each with very different bearing arrangements. What readily distinguishes a '35 drum from the '32-'34 drums are its raised ribs on the outside horizontal surface (when mounted) as shown in DD's photos which the earlier drums lack.
Old 08-30-2021, 06:43 PM   #6
russcc
Is the difference between the '33-'34 drum and '35 just the ribs on the perimeter of the drum ? Any other differences ? Thank you.
Old 08-30-2021, 07:02 PM   #7
Mart
Mart's Avatar
I believe the 35 drums are wider than a 32-34 drum. They can accommodate a 1-3/4" wide shoe vs 1-1/2".
Mart.
Old 08-30-2021, 07:04 PM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
No, brake shoe contact width is greater on '35 drums compared to '33-'34.
John
Old 08-30-2021, 08:51 PM   #9
cas3
from what I have seen, 35's have the 3 ribs around the drum like coopman's picture, and 32-34 have one rib
Old 08-31-2021, 05:12 AM   #10
russcc
So it sounds like the only functional difference is a wider swept brake area on the '35 vs the '32-34.
Old 08-31-2021, 10:45 AM   #11
rich b
rich b's Avatar
'35 uses a normal inner seal pressed into the hub; while '32-'34 uses a steel ring slinger pressed onto the spindle like a Model A.
Old 08-31-2021, 11:12 AM   #12
DavidG
DavidG's Avatar
No ribs on '32-'34 drums unless you count the outer perimeter as a rib, which it sort of isn't in the sense of the ribs on a '35 drum, but rather serves as a slinger to minimize the intrusion of rain water into the brake drum while underway. If you count that as a rib, then the '35 drum has four ribs, not three.
Old 08-31-2021, 02:43 PM   #13
JSeery
JSeery's Avatar
Posting some photos might help some. If you can't get them to post you can email them to me. [email protected]
Old 09-10-2021, 01:53 PM   #14
rich b
rich b's Avatar
I had this axle kicking around, waiting to be taken, for a couple years. Just noticed there is something not quite right about it.
Guess I need to move it to the front of the line to see what is going on.
Old 09-10-2021, 02:11 PM   #15
cas3
35 drum on a 32-34 axle ?
Old 09-10-2021, 02:27 PM   #16
DavidG
DavidG's Avatar
It appears to be a '32 front axle and not either the '33 or the most common, the '34 version. (All of which are functionally equal.)
Old 09-10-2021, 04:20 PM   #17
Mart
Mart's Avatar
Is it a "heavy" (32) axle I can't really see. What says it is not a 35 axle?
Old 09-10-2021, 04:30 PM   #18
rich b
rich b's Avatar
The '32-'34 spindle gives it away.
It's not a '32 axle; it's the later "skinny" axle used up until '36.
I just thought it funny after walking by it all the time I never noticed that it had later drums on it. I mean multiple times a week for several years.
Old 09-10-2021, 04:39 PM   #19
Mart
Mart's Avatar
Oh of course, yeah, the 35 spindles are cross steer.
