Old 08-29-2021, 03:50 PM   #1
Ramblin Reck
Ramblin Reck's Avatar
Default 39 Ford Hood does not close and fit properly
All four opening and closing hinges are there but do not function properly. I have to move the hood around in a sideways fashion to get it to open and now it closes but there is a large gap on the sides and at the back. Would a new set of hinges solve this problem? Thanks
ORDERED NEW HINGES. WILL ADVISE RESULTS
Ramblin Reck is offline   Reply With Quote
Old 08-29-2021, 05:19 PM   #2
34PKUP
34PKUP's Avatar
Default Re: 39 Ford Hood does not close and fit properly
Most likely not. Unless noticeably damaged
It is a matter of being able to understand what happens when the mounting bolts are loosened and the (2) hinges can be rotated and raised and lowered to give the desired outcome.
The (2) spring supports generally do not come into play for adjustment.
34PKUP is offline   Reply With Quote
Old 08-29-2021, 06:25 PM   #3
quickchange34
quickchange34's Avatar
You need to set and center the hood first. Then loosen all of your front sheet metal and adjust to fit the hood . Its not easy , it takes time. You may have to open some of the holes .
quickchange34 is offline   Reply With Quote
