#1 |
I have a motor that ran very good, we have let it sit for several years now there is no compression in any of the cylinders. Is there any thing I can add to the cylinders I assume it has to be the rings. Thanks
#2 |
Put some MMO into the cylinders and let it soak for a day...try again
#3 |
Take plugs out and look to see if valves are all moving
#4 |
I agree with Kurt, stuck valves. We had one with two dead cylinders just the other day. Exhaust valves stuck open.
Ruth "Sometimes you really DO need to read the whole thread" |
#5 |
There is recent thread regarding this that wa started by Grampy.
#6 |
IN GOD WE TRUST - SEMPER FIDELIS John
#7 |
When I bought my 31 Town Sedan it had no compression also. It sat in a garage for several years, and I found the teeth were stripped off part of the cam gear, so it didn't rotate.
Watch the distributor rotor to make sure the cam is turning. |
