Old 08-29-2021, 08:40 AM   #1
Randy Lausch
Default Where did my compression go
I have a motor that ran very good, we have let it sit for several years now there is no compression in any of the cylinders. Is there any thing I can add to the cylinders I assume it has to be the rings. Thanks
Randy Lausch is offline   Reply With Quote
Old 08-29-2021, 08:44 AM   #2
burner31
burner31's Avatar
Default Re: Where did my compression go
Put some MMO into the cylinders and let it soak for a day...try again
Keith
Shawnee OK
'31 SW 160-B
Old 08-29-2021, 09:36 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
Take plugs out and look to see if valves are all moving
Old 08-29-2021, 09:38 AM   #4
Ruth
I agree with Kurt, stuck valves. We had one with two dead cylinders just the other day. Exhaust valves stuck open.
Ruth
Old 08-29-2021, 10:53 AM   #5
Patrick L.
Patrick L.'s Avatar
There is recent thread regarding this that wa started by Grampy.
Old 08-29-2021, 12:39 PM   #6
jayvee34
jayvee34's Avatar
Smile Re: Where did my compression go
Originally Posted by Patrick L. View Post
There is recent thread regarding this that was started by Grampy.
The thread is titled "It ran well when I parked it" is toward the bottom of this page.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 08-29-2021, 11:22 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
When I bought my 31 Town Sedan it had no compression also. It sat in a garage for several years, and I found the teeth were stripped off part of the cam gear, so it didn't rotate.
Watch the distributor rotor to make sure the cam is turning.
