Old 08-01-2021, 09:19 AM   #1
jerrytocci
Default Trans fluid on driveway
My transmission drips a couple tablespoons after a drive and seems to be coming from the "keeper/clip" in the back of transmission . Is there a way to stop the leaking??
jerrytocci is offline   Reply With Quote
Old 08-01-2021, 09:26 AM   #2
Will N
Will N's Avatar
Default Re: Trans fluid on driveway
Are you sure it isn't engine oil from the rear main running down and dripping off the transmission?
Will N is offline   Reply With Quote
Old 08-01-2021, 09:30 AM   #3
Y-Blockhead
Y-Blockhead's Avatar
[/FONT]
Not sure what you mean by "keeper/clip"? Do you mean the bolt and plate for the reverse idler and cluster shafts? If so the vendors sell a "seal" kit for them.
https://www.snydersantiqueauto.com/P...earchByKeyword
It works well, so well that mine has no oil on it and is rusting...
Old 08-01-2021, 11:08 PM   #4
CWPASADENA
CWPASADENA's Avatar
https://www.snydersantiqueauto.com/P...SION-SEAL-KIT?
Works great.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 08-01-2021, 09:40 AM   #5
jerrytocci
Thanks . That is the area and I will buy one of those
Old 08-01-2021, 10:35 AM   #6
duke36
Helps to drain the lube, then pack mating surfaces and bolt with "right stuff"
sealant.
duke36 is offline   Reply With Quote
Old 08-01-2021, 12:09 PM   #7
Mulletwagon
Mulletwagon's Avatar
If ever rebuilding the trans might consider the O Ring style cluster and reverse gear shafts. Works well !
Mulletwagon is offline   Reply With Quote
Old 08-01-2021, 02:01 PM   #8
w.michael
w.michael's Avatar
Check to make sure the vent hole in the back of the shift tower is open, so that no pressure builds up in the transmission as it heats up.
W. Michael
w.michael is offline   Reply With Quote
Old 08-01-2021, 04:52 PM   #9
jerrytocci
Thanks to all replies
