Old 07-17-2021, 02:01 PM   #1
FrankWest
FrankWest's Avatar
Default 1933 transmission "gear" oil
It has been a while since I purchased Transmission gear oil. What is available now. Remember that sae 900 crap that was like refuse from a burger pit?
FrankWest is offline   Reply With Quote
Old 07-17-2021, 02:25 PM   #2
David J
David J's Avatar
Default Re: 1933 transmission "gear" oil
Sta-lube SAE 140 . GL4
David J is offline   Reply With Quote
Old 07-17-2021, 02:33 PM   #3
Shoovel
Shoovel's Avatar
Yep, that’s what I use.
Shoovel is offline   Reply With Quote
Old 07-17-2021, 02:49 PM   #4
Pete
Old 07-17-2021, 03:09 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Pete View Post
Depends on the transmission.
I use ATF in my T5.
I use ATF in my T5.
He CLEARLY states "1933 transmission "gear" oil" in the header....less than 1 inch away from where you question the transmission type! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-17-2021, 03:13 PM   #6
19Fordy
19Fordy's Avatar
For GL4 140 you can't beat O'Reilly's price on the shelf.
https://www.oreillyauto.com/shop/b/c...w/754ba5cbea99
Old 07-17-2021, 03:17 PM   #7
Pete
I use ATF in my T5.
I see that now. Thanks.
Old 07-17-2021, 03:44 PM   #8
VeryTangled
VeryTangled's Avatar
Hi Everyone. Frank, I hear you can get it at NAPA, but I usually get it delivered.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 07-17-2021, 05:54 PM   #9
FrankWest
FrankWest's Avatar
Thanks guys...with your help I just ordered a gallon.
Old 07-17-2021, 07:07 PM   #10
Reds34
Not to hijack, but is that what you guys use in the rear axles too?
Thank you.
Red
Reds34 is offline   Reply With Quote
Old 07-17-2021, 07:33 PM   #11
David J
David J's Avatar
yes here
Old 07-17-2021, 07:39 PM   #12
Brian
Brian's Avatar
I've always used 80W90 GL4 in the trans....would I be better off running 140? Why?
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 07-17-2021, 11:02 PM   #13
David J
David J's Avatar
Talking Re: 1933 transmission "gear" oil
33-34 trannys make less noise in low and it seems to make shifting a little better .
JMHO of course but rezin nuff fer me .
Old 07-18-2021, 10:06 AM   #14
19Fordy
19Fordy's Avatar
Thank you.
Red
Yes! Opps, pretty large font.
Old 07-18-2021, 07:46 PM   #15
Talkwrench
Talkwrench's Avatar
More to do with climate BB .. Im now trying the 85-140 mineral from Penrite its a GL5 but its supposed to be ok. As you know Im sub tropical no freezing here ..
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 07-18-2021, 08:00 PM   #16
Brian
Brian's Avatar
Oh, ok. I see Shoovel, who lives in Ontario, Canada, shares the same climate as Perth, WA lol
