Old 05-29-2021, 08:16 PM   #1
1930artdeco
1930artdeco's Avatar
Default 272 vs 292
Are there any differences between the two engines 1957 model year? Can the 272 be upgraded to a 292?
Thanks,
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 05-29-2021, 08:43 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 272 vs 292
Looks like it.
They use the same crankshaft dimensions and rods, but the bore is different...
The 292 blocks may(???) have been cast slightly thicker at the cylinder walls to accommodate the larger bore but I don't know.
http://ford-y-block.com/dimensions.htm
http://ford-y-block.com/displacement.htm
http://ford-y-block.com/technical.htm
dmsfrr is offline   Reply With Quote
Old 05-30-2021, 05:10 AM   #3
darrell
ive bored 3 of them to 292.everything is the same in 57.the walls are about 1/16 thinner on average but thats no different than boring a 292.060
darrell is offline   Reply With Quote
Old 05-30-2021, 06:31 AM   #4
Hot Rod Reverend
Hot Rod Reverend's Avatar
This is the best route to go for rebuilding a 272 since 292 pistons will be much, much cheaper. Go standard bore for 292 pistons and you are good to go.
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
